Problem with Antique Sounds Pre Amp
Old 26th February 2015, 03:17 AM   #1
ToulMan is offline ToulMan  United States
Default Problem with Antique Sounds Pre Amp
I have an Antique Sounds AQ-2004DT pre amp. I've had it for a little over 12 years. It is putting out volume to the left channel when the volume knob is turned all the way down. It has been doing this off and on but now it seems to do it consistently. Any ideas?
Old 26th February 2015, 04:06 AM   #2
rayma is online now rayma  United States
Probably it's related to the volume control, maybe a bad connection, or internal mechanical wear. It should be easy to replace.
Old 3rd March 2015, 11:29 AM   #3
Burnedfingers is offline Burnedfingers  United States
IS this it?
Old 3rd March 2015, 11:35 AM   #4
Generally the quality of OEM controls isn't very good. If it were me I would replace the stereo volume control with a stepped unit. Maybe rat shack still has some left or possibly order from Mouser. Some controls simply seem to bleed a little audio at the bottom end and it can also depend on the strength of the signal coming to the preamp.
Problem with Antique Sounds Pre AmpHide this!Advertise here!
Mic pre amp Problem Blacknight Analog Line Level 51 10th May 2011 07:57 PM
Headunit pre amp problem. bass junkie Car Audio 6 25th May 2010 01:54 AM
T-Amp and Pre Amp shared power problem tedlevit Class D 3 26th February 2008 03:22 PM
Phono pre amp RF problem eddievanjealous Tubes / Valves 26 21st January 2008 02:33 PM
Biasing pre-amp problem HOMER_PT Tubes / Valves 3 20th February 2006 11:58 PM
