simple design power amp.. wanted. - diyAudio
Old 28th January 2004, 08:50 AM   #1
GeirW is offline GeirW  Norway
GeirW's Avatar
Default simple design power amp.. wanted.
ciao.
have been looking around for a suitable
tube amp. design. many links here to chose from,
but i haven't found what am looking for yet.
am a totally newbie on amp designs
so i asking for some assistance.
what am after is a power amp. with tubes,
how big..(not realy that important right now..
that depends of A or A-B i guess.)
my main concern is ohm load, power usage,
simple design, cost.. and either it would be
single ended or a push-pull.. mainly coz.
i`ve heard SE amp`s have cleaner sound.
and these would be easier to assemble i assume.
help is appreciated.
Old 28th January 2004, 02:27 PM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
what is your speaker sensitivity?
Old 28th January 2004, 03:31 PM   #3
GeirW's Avatar
ciao.
91.5 dB (2.83/1m)
nominal: 4 Ohm
it`s a Dappolito design..
i wanted to go back to 3-way earlier.. but my current
amp.. is capable.. but is a bit weak.
and beside.. i love the tube sound..
and to add.. i use only speakers
that has a nominal of 4.
Old 28th January 2004, 07:26 PM   #4
Scytales's Avatar
With such specs, i would be interrested in the answer to.
________________
Ce n'est pas se donner que de donner ce qu'on voudrait Ítre. (Patrick Drevet)
Old 28th January 2004, 07:52 PM   #5
GeirW's Avatar
ciao.
@Scytales.
what`s specs. do you refer to..
Old 28th January 2004, 11:58 PM   #6
Default need more info
I think for the folks to help here you need to give more info such as:
purchase or DIY? your skill level? experience level? how loud? listening environment? type of music? power requirement? You know, the basic stuff for everyone to consider in order to make suggestions.
Even with those speakers, some people would be happy with 2 watts--others would not consider anything less than 16 watts as adequate.
Old 29th January 2004, 09:46 AM   #7
GeirW's Avatar
ciao.
OK.
of course it would be a diy..
skill level : as good as none..
this will be my first amp.
thus.. not totaly.. as most ppl. i grew up with a solder.
how loud : loud enough to get the "live" feeling.
enviroment : normal living room.. quite bigg. consist of
wooden panels which make it somewhat analytical.
type of music : mostly 60-70 rock.. some jass.. synth pop.. and
clasical from time to time.. NU-metal.. punk.. Black metal.
vinyl before 88.. cd after.
power req : my current amp. is a (ca) 2x75 in 4.. (Tr) it`s
bigg enough for 2-ways.. but i assume it would reveal some lacks
in a good 3-way.. thus the speakers am talking about would be
2.5 ways.. but will have a 3w. loading.
would this info do.. ?
(btw. sorry to not have mentioned this earlier.)
Old 29th January 2004, 02:04 PM   #8
Default Kit
I am thinking a kit is probably best but something with some power. Probably would be satisfied with a push-pull in the 10-40 watt per ch. Probably be dissappointed with SET in the 2-8 watt range-but maybe not.
I cannot offer any kit suggestions for pp--maybe someone else here could.
Best of luck,
Rick
Old 30th January 2004, 03:41 AM   #9
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Try a single ended design. They are far easier to build than a push pull design (1/2 the complexity!) and sound great. They are the perfect choice for a beginner. Look at a kit, there is some great value out there, like the bottlehead stuff.
If you build, say, a single ended EL34 in pentode mode, you can easily get enough power, probably 8-10W. A triode like 300B comes with massive cost penalty. Use a little negative feedback to keep it linear, and you will have a great sounding amp.
I used a 3.5W 6B4G triode amp on my 89dB B&Ws and it was pretty loud, definitely filled the room with clean, sweet sounding music!
Old 30th January 2004, 02:44 PM   #10
mcs is offline mcs  Denmark
Default Re: simple design power amp.. wanted.
Originally posted by GeirW
ciao.
SE - clean sound? No, not at all. Good sound? Yes, certainly!
An SE amp has very high distortion at max. power (but very low at low levels), so I wouldn't call it clean - but it certainly sounds nice.
Here's my attempt at designing an SE amp: http://stiftsbogtrykkeriet.dk/~mcs/2A3.gif
Works well, but if this is your first project you would probably need more than just a schematic...
Best regards,
Mikkel C. Simonsen
Simple Magic Eye Circuit Wanted poynton Tubes / Valves 8 26th November 2014 09:02 AM
Wanted. Simple EL34 Push Pull Design jack firebrace Tubes / Valves 51 29th July 2013 12:47 AM
Help (very much) wanted for simple quarter-wave design for cheap drivers. Spasticteapot Full Range 9 4th May 2006 09:14 PM
simple UC3825(A) or SG3525 schematic wanted Kuzmenko Class D 1 4th April 2005 05:27 PM
SIMPLE SE amp design wanted DrewP Solid State 3 25th August 2003 04:59 AM
Copyright ©1999-2017 diyAudio
