measuring wattage?
hi, ive got a realy old haker valve amp for my guitar, i would like to find out what wattage its producing? i have a basic grounding in electronics (qualIfied 15 years ago grade 3 technicin, gave it up though.DOH) but i havent done any thig with valves and its been a while :)
i know theres some deadly stuff going on inside this valve stuff but i want to learn. its so old it has no markings. was going to build my own(see other posts) so thought this would be a good one to maybe strip down and play with
thx in advance for any help
You'll need a sine wave generator, a dummy load (like an 8 ohm power resistor), and an oscilloscope. Substitute the dummy load for the speaker, hook the 'scope across it, run the output of the generator into the input of the amp (use a midrange frequency like 1kHz), then turn it up until you see clipping at the output (i.e., when the tops of the sine wave start to flatten out). Reduce the level until the flattening just goes away, then look at the peak to peak voltage at the output. Average power can be calculated by squaring the voltage, then dividing by 32 (assuming an 8 ohm dummy load).
You don't need to dig into the hazardous high-voltage guts of the amp to do this measurement.
And as FB says, you can at least get a ballpark idea if you know what the output tubes are and their B+ voltage, though that requires a bit of probing around potentially lethal voltages- take precautions against the possibility of shock.
no thats fine, i didnt take it the wrong way :). yea it is hacker , sorry spelling mistake.( god looked through post, imust look at the creen when i type :))
i have knowledge of electronics its just i have never worked on valve stuff before! i was trained in "semi" stuff and low voltage. i just want to make sure iam going to do it correct. do the caps in these sorts of amps act like those in tv sets by holding there charge after switching off?
iam going to have a go at buiding the p1 AX84
and that is supposed to be a beginers project. iam just gathering as much info as i can b4 i start :) iam going to get hold of a book called "the tube amp book" by aspen pittman. my guitar teacher recomends it.
thx
