Can Capacitor - diyAudio
Old 15th February 2015, 05:10 PM   #1
Default Can Capacitor
Hello,
Well here is another novice question. Restoring an amp from chassis up. I am re assembling now and even though I took pics or it from every angle and know from those how the can capacitor was before does it matter how it is mounted on the chassis. I looked it over from top to bottom and the only writing is the label of the make and capacitance of the can. Is there a sequence say like a tube? Thanks everybody.
A novice in training.
Chris
Old 15th February 2015, 05:17 PM   #2
nigelwright7557's Avatar
The pin connections are important as some are positive connections and some are negative. Get it wrong and the can will explode.
Some cans just have 2 connections but many valve amps had multi capacitors in one can.
PCBCAD51 pcb design software. http://murtonpikesystems.azurewebsites.net/
Old 15th February 2015, 05:18 PM   #3
This one has four plus the twist locks
Old 15th February 2015, 05:19 PM   #4
It is a Mallory 40/30/10/20
Old 15th February 2015, 05:20 PM   #5
Have you got a picture of the connections ?
Old 15th February 2015, 05:22 PM   #6
Hold on b right with ya
Old 15th February 2015, 05:23 PM   #7
I found a couple using google but none shows the pin out.
Did you not write down the connections when you disconnected the wires ?
Even if you know the pin out do you know which wire connects to each pin ?
Old 15th February 2015, 05:28 PM   #8
Yes i ha e a schematic and pics so i will be ok pretty sure. Here are some pics.uploadfromtaptalk1424024887040.jpguploadfromtaptalk1424024905106.jpg
Old 15th February 2015, 05:31 PM   #9
It looks like 3 capacitors with a common ground.
Does the terminal end have markings on it for what each capacitance for that pin is ?
Old 15th February 2015, 05:39 PM   #10
If it's a 40/30/10/20 the metal case should be the ground. The case tabs were typically soldered to the chassis. The cap tabs should have a symbol denoting which is which. A square, triangle, circle, so on and it will match up with one of the mfd ratings on the label.
What value is this Capacitor? Jclay85 Instruments and Amps 2 26th May 2012 01:32 AM
mkt capacitor vs mylar capacitor Vrystaat Solid State 1 28th March 2012 08:18 PM
Help needed - reservoir capacitor after reservoir capacitor wwenze Power Supplies 8 29th October 2010 01:16 PM
Capacitor or not? future Parts 2 24th June 2003 11:10 PM
What is this capacitor for? Christian Chip Amps 16 14th April 2003 03:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
