Quicksilver 6550A's?
Old 28th January 2004, 06:48 PM   #11
lpd is offline lpd  Canada
I'm not sure what the b+ in the KT88 monoblocks is, but I'm assuming its about 450-475 margin. I'll pull out the vm tonight and check the voltages.
Old 28th January 2004, 08:05 PM   #12
richwalters is offline richwalters
richwalters's Avatar
Okay at the bench- with my switchable B+ homemade amp. I'm running at 485V B+ using parallel P-P UL 2,25K A-A with 6550B's, just squeezing 135W per ch. Tubes reasonably well matched give excellent AB1 performance. I find 6550's give lowest THD at app 65mA/quies/ tube.
Another interesting situation occurs at reduced B+ of 250V using same circuit but 95mA quies /tube. At reduced Pout of 25W, Anode current =100mA per tube n'st damm it class A.
THD in both power cases well below 0.1% at 1dB below clip with 20dB fb..
enclosed excel graph..I hope this comes through.....my machine isn't the best to use..for attachments....
rich
Quicksilver 6550A's?Hide this!Advertise here!
6550a question for engineer? KJ2005 Tubes / Valves 59 24th November 2009 03:33 PM
Quicksilver lpd Tubes / Valves 10 9th March 2009 02:55 AM
Quicksilver? lpd Tubes / Valves 20 2nd January 2004 01:17 AM
quicksilver 8417 hum dreaded 42 Tubes / Valves 4 11th September 2003 02:45 AM
Quicksilver 8417 dreaded 42 Tubes / Valves 4 4th September 2003 11:14 PM
