need a good 2a3 socket... need advice - diyAudio
Old 7th February 2015, 10:02 PM   #1
lexx21 is offline lexx21  United States
Default need a good 2a3 socket... need advice
I am in the process of building a 2a3 amp and want to use good and reliable 4 pin sockets. I have some Chinese made sockets, but in the past I have used old soviet sockets for my octals. I have yet to find soviet 4 pin sockets for my needs (would really like to if they exist).
Can someone here point me in the right direction for good quality 2a3 sockets?
Old 8th February 2015, 02:20 AM   #2
Johnson made them back many years ago, I believe a Johnson 209 is for small 4 pin tubes.
Old 8th February 2015, 03:13 PM   #3
Palustris's Avatar
Epay sometimes has excellent vintage USA sockets but you may have to be patient. You can search for Johnson, Cinch, National, and Amphenol. I usually buy them when I see them so they are "in stock" when I need them. One vendor has been selling NIB 4 pin Amphenol sockets for about a year but I don't know if he has them on epay at the moment.
Old 14th February 2015, 02:05 AM   #4
Found some Nationals on epay and they are on the way. Thanks for the advice.
I will have to clean the contacts though. Thinking that some Deoxit will work for the job.
Old 14th February 2015, 06:18 AM   #5
Be careful with contact cleaners that leave a residue... The residue will contribute to arcing between socket pins, which usually has negative results.
The residue attracts dust and dirt. Use a no residue contact cleaner.
Need advice selecting a 2A3 design lquintas Tubes / Valves 10 16th April 2014 09:04 AM
sunaudio 2A3 circuit...is it good for newbie? chanwt Tubes / Valves 4 8th April 2013 03:53 PM
Need some advice where to install LED, also power socket advice. Mull3t Construction Tips 14 28th May 2012 04:32 PM
good replacement for op-amp njm2737? socket for SMD? ljames Digital Source 5 23rd November 2011 07:05 PM
Any advice on modifying a 2A3 SET amp to parafeed? zman3 Tubes / Valves 4 2nd March 2008 07:30 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
