PPP EL84 monoblocs: i knew then what i know now... - diyAudio
Old 3rd February 2015, 11:48 AM   #1
bullpeters's Avatar
Location: Right next to beach, a potatoe toss to the whitewater
Default PPP EL84 monoblocs: i knew then what i know now...
I started this project three or more years ago. I keep learning as i go along, so new problems come up all the time. i have matching Choke and PT and OT so i thought that a tube rectifier would be cool. I notice i have 5v 2 amp tap on the transformer. Well that limits my rectifiers and i also notice that my input tube
e88cc has a pretty demanding anode current. 15ma. I am really hoping that is for both triodes otherwise, by my often faulty calculations, i need 4 x 46ma for the anodes, 4 x 11ma for the grids of my EL84 (300v plate ultralinear) equals
228ma plus the 15ma for the e88cc gives me 243ma. If its 15 per triode then i am unsure what rectifier to use. I planned on GZ34, the heater currents good but with 250ma that seems to be cutting it close. I have 5AS4 but not enough heater current. I have also punched the hole and it will look stupid empty.
Can some one check my math. 4 EL84 and 1 ECC88. 300v Plate, ultralinear.
GZ34 rectifier. Gonna work???
Old 3rd February 2015, 12:45 PM   #2
there is no reason to tun ECC88 at 15 mA per anode, the linearity is great at 4..5 mA. Most designs use them in that area
Old 4th February 2015, 01:35 AM   #3
bullpeters's Avatar
Light bulb!
Admin, you can delete thread if you want. sorry to waste your server space
Old 4th February 2015, 01:47 AM   #4
cerrem is offline cerrem  United States
What about a MV type 83 ....works with 5V ...
Cathode bias for EL84 PPP oyvinsa Tubes / Valves 5 19th February 2014 05:22 AM
Guitar amp schematic for PPP EL84 Charles Wasserf Tubes / Valves 6 5th January 2010 08:01 PM
ppp el84 fixed bias schematics jogas Tubes / Valves 17 31st August 2009 02:02 PM
Anyone have a single el84 PPP OPT? whatsnext Tubes / Valves 2 20th November 2005 03:34 AM
PPP EL84 Amp Peter Menting Tubes / Valves 8 24th August 2005 06:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
