need help searching for ground - diyAudio
Old 1st February 2015, 03:05 PM   #1
djn is offline djn  United States
djn's Avatar
Default need help searching for ground
Hi all, I am looking for a thread on the best way to run ground on a tube amp. For some reason the search function isn't working.
Sooo, can some post a link or two on the best way to wire the ground in my amp build.
My "Art" website http://home.comcast.net/~djnagle/site/
Old 1st February 2015, 03:08 PM   #2
merlin el mago's Avatar
Audio Component Grounding and Interconnection
Old 1st February 2015, 05:07 PM   #3
djn's Avatar
Thanks Merlin.
shield ic chip at analog ground or digital ground? KevinLee Digital Source 2 17th July 2012 01:15 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 04:50 PM
New guy with DIY ground ?s--yes, even after searching:D pushpull7591 Tubes / Valves 4 29th April 2005 05:38 PM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 02:08 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 01:55 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
