Boyuu EL34 A9 Tube Amp
Old 28th June 2018, 10:46 AM   #401
Mission720 is offline Mission720  United Kingdom
Hi wishmasterX
I have the Boyuu A10 EL34 SE amplifier. This is point-to-point wired with 'Japanese' uprated power and output transformers. It would be easy to modify, but I have not had time or requirement to do so yet.
I have owned this for 18 months now, having bought fully assembled. It came stock with EL34 Shuguang tubes and 6N2 chinese double triodes and stock rectifier.
I am in the UK and the voltage is very stable, although I've not measured it at primary or outgoing of rectifier valve.
Without any modifications I have just dropped in EL34, EL34B, 6CA7, Shuguang 350C, 6P3P, KT77 and finally 6N3C-E and they have all 'worked' but I have not measured their performance.
I have also tried two different types of solid-state drop-in rectifiers with various valve combinations.
When I have time I will check the o/p valve bias currents and also the various B+ and other voltages for each combination.
The power and output transformers have not got overly hot at all in any of the above configurations. They are warm to the touch after a few hours but that's all.
Hope this helps.
Old 7th July 2018, 03:56 PM   #402
JohnnyEcho is offline JohnnyEcho
Default Boyuu A9 Builder Looking For Help
Hi All
After Watching All The Fun You Are all Having Building The Kit, I Took The Plunge And Bought One.
Now All Went Well Until I Came To Test It, (apart from pins 1 & 4 on the input tubes not shown as linked on the schematic, Picked that up from your forum)
First I Had A Very Loud Hum/Buzz On Both Channels, After Checking Everything And Moving The Heater Supplies Away From Any Input Wires/Pins, It Did Reduce.
My Problem Is That I Still Have Quite A Loud Hum/Buzz But As Soon
as Any input signal is connected, the amp plays it at full volume, regardless of the volume position.
almost as if i have built a super sensitive amp?
I have checked the volume control and it's working as it should, (checked with my calibrated fluke).
Has anyone got any ideas?
Anything Considered.
I'm Confident with electronics and have built many electronic kits but this is my first valve project.
Thanks,
John.
Old 7th July 2018, 10:10 PM   #403
6A3sUMMER is offline 6A3sUMMER  United States
Sounds to me that one or the other of the RCA phono connector input ground, bottom of the 100k Ohm volume pot, and the common ground of the amp are not all connected together.
Old 8th July 2018, 02:24 PM   #404
Hi 6A3sUMMER.
Thanks For Quick Reply, You Were Spot On.
After Checking Out The Volume/RCA input lines, Found A Dry Joint At The RCA Circuit Board Ground To RCA Socket Grounds.
Only Found It By Measuring Between Ground on RCA Circuit Board And RCA Sockets Outers On Rear Panel.
Looks Like I Made The Joint Good When I Pressed The Probe Of My Meter On It, While Testing It?
Anyway Now My Amp Is Working Almost Perfectly.
I Do Have A Slight Buzz You Can Only Hear At Very Low Volume Or Quite Sections in-between Tracks.
I'll Have Another Go After Its Settled In Awhile.
Thanks Again, Your Help Is Greatly Appreciated.
John
Old 14th July 2018, 07:59 PM   #405
kirtbynoe is offline kirtbynoe
Hello All,
After reading and re-reading this thread (very informative but soooo long), many thanks for all the valuable info and knowledge thats been contributed. I'm just about to start a build on an A9. I want to incorporate the mods by Geek Stuff. Does anyone have an opinion of what order to follow for the build? I'm thinking that I would wire in the components on the PCB first then the coax, followed by the transformer, AC, B+ etc. and finally the components from the valves to the PCB. Any help would be gratefully accepted. If I've missed this somewhere in the thread please forgive me.
Boyuu EL34 A9 Tube AmpHide this!Advertise here!
Boyuu hifi Equis A10 EL34B+6N2 SE Tube Amplifier with 5Z4P rectifier: review and mod ygg-it Tubes / Valves 55 21st January 2018 03:21 AM
My new el34 + 12ax7 VCT amp. (Need Ideas For my first headphone vacuum tube amp Too~) briansune Tubes / Valves 10 12th July 2013 05:33 PM
FS: DIY EL34 / 6SN7 Tube Amp john65b Swap Meet 2 12th March 2012 02:02 AM
EL34 tube amp that needs work on el34ecc88 Tubes / Valves 0 17th December 2008 08:05 AM
EL34 vs. 6L6GC for 1ST DIY Tube Amp? pjkunz Tubes / Valves 4 17th December 2001 02:51 AM
