Output Transformer Windings in parallel - diyAudio
Old 30th January 2015, 04:37 PM   #1
apnneto is offline apnneto  Brazil
Default Output Transformer Windings in parallel
When the secondary are connected in parallel, as in the drawing below, which is the final impedance? I need this information to adjust the feed back loop.
Any help is welcome.
Old 30th January 2015, 05:02 PM   #2
ruffrecords's Avatar
It will be one quarter of what they were in series.
Cheers
Ian
Old 30th January 2015, 05:13 PM   #3
smoking-amp's Avatar
That OT diagram looks a lot like the setup that Hammond uses (or used to on older OTs). An 8 Ohm winding with a 4 Ohm tap. Connecting the other 4 Ohm winding across the 0 and 4 Ohm tap just increases the current output capability, still 4 Ohm across the 0 to 4 tap and 8 Ohm across the 0 to 8 taps.
You connect the extra 4 Ohm winding in series with the 0 to 4 Ohm taps to get 16 Ohm out from the series combo. Looks like the diagram has the extra winding connected across the wrong taps. (will smoke the OT in that case since the 4 to 8 Ohm taps are actually a 2 Ohm winding, not 4)
Old 30th January 2015, 05:21 PM   #4
Ok, Thank you ,
but is this true if the windings impedance were with different values? In this case, 4-8 is in parallel with 0-16.
Old 30th January 2015, 05:25 PM   #5
jazbo8's Avatar
"0-16" is actually another 4R winding as smoking-amp said, here is the wiring diagram for the Hammond OPT, which should be similar to the one used in TVA-1.
Old 30th January 2015, 05:27 PM   #6
Originally Posted by smoking-amp View Post
That OT diagram looks a lot like the setup that Hammond uses (or used to on older OTs). ...
Thank you, but this is Michaelson & Austin power amplifier and the drawing is ok.
Unfortunately, I don't have a unit to do some measurements. It uses half of 8 ohm (winding) to connect in parallel with 0-16 windings.
Old 30th January 2015, 05:29 PM   #7
Got it. Now makes sense. Thank you.
Old 30th January 2015, 06:03 PM   #8
Tom Bavis's Avatar
It's labeled in a misleading way - windings need to the same number of turns to be connected in parallel, or it will be effectively a number of shorted turns.
Old 30th January 2015, 06:18 PM   #9
That's why it makes sense. Two windings of 4r in parallel.
Thank you for confirm that.
Old 30th January 2015, 06:39 PM   #10
That interesting the label on the OT, as shown in the picture below ... Why that
Maybe to avoid clone the power amp?
Parallel transformer output rodrigosalvati Analog Line Level 26 22nd June 2014 10:46 PM
Parallel Output transformer question deicide67 Tubes / Valves 5 19th November 2012 10:47 PM
FS: 2 EXO-050 SINGLE-ENDED PARALLEL FEED (PARAFEED) OUTPUT TRANSFORMER NICKEL LAMS makingmoney Swap Meet 1 21st February 2012 03:59 PM
FS: ONE EXO-050 SINGLE-ENDED PARALLEL FEED (PARAFEED) OUTPUT TRANSFORMER makingmoney Swap Meet 0 18th February 2012 09:09 PM
Parallel secondary windings jlm Pass Labs 6 27th March 2004 11:39 AM
Copyright 1999-2017 diyAudio
