Tube amp help - diyAudio
Old 28th January 2015, 12:14 PM   #1
Default Tube amp help
I've just managed to bag myself a few NOS valves from someone I know and wondered if anyone could advise on possible headphone applications for them
These are what I have
EL86 (3 off)
ECC82 12AU7 (1 OFF) I've seen a few designs using one of these
PL508 (2 off).
Any help would be very much appreciated
Old 28th January 2015, 02:08 PM   #2
You could build a simple single-ended OTL like this one with ECC82 and 2x EL86, for example. (This one is so simple it doesn't even have any gate stoppers. I'd want to check stability in practice.) Obviously it would be mostly for mid-high impedance cans (>100 ohms or so), and certainly not for ones known to be fussy about low output impedance or very sensitive ones that would make every last bit of noise heard, and I would normally prefer a more advanced topology. It'll also generate its share of heat (about 17 W in total for heating + idle currents). But it should work.
Old 28th January 2015, 02:12 PM   #3
Thanks for the quick response, I'll certainly take a look at it, I'm trying to get back into building things, so I don't mind trying a variety of options to get something I'm truely happy with.
Old 28th January 2015, 03:00 PM   #4
20to20 is offline 20to20  United States
20to20's Avatar
You are starting this project backwards. The value of the tubes is minor compared to the cost of the entire unit you want to build. You should decide what you want from a headphone amp and build the right circuit with whatever tubes it needs. Sell what you have to fund what you really want or keep them for another project. Don't build an amp around the tubes you have unless by luck they just happen to fit a great amp circuit. G'Luck! 20
Old 28th January 2015, 03:17 PM   #5
Thanks for the input 20to20, I see your point for sure, I only bought the box of tubes because I wanted the ECC82 for a project and I got such a good deal on them as a bundle. I've got no problem selling on the tubes to get something more appropriate, but I just wondered if there was anything that could be done with the ones I have already.
Tube vs. Jfet Preamp for Dynaco ST-35 tube power amp rcollege Tubes / Valves 16 25th November 2013 10:56 PM
my 250 watt tube amp can be a 500 watt tube amp for less than 2 bucks plus tubes speakerfritz Tubes / Valves 17 24th October 2013 11:50 PM
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 04:14 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
