RCA 6146B sub for 807 or 6L6? - diyAudio
Old 23rd January 2015, 07:11 PM   #1
Default RCA 6146B sub for 807 or 6L6?
I managed to acquire a pair of RCA 6146B tubes recently, and I'm interested in building a single-ended stereo amp with these as output tubes.
I have read through every thread I could find on the 6146B on this and various forums, including warnings and caveats about non-linearity, large disparity between plate and grid voltage, and so on.
However, it appears that at least some folks feel that one can build such an SE amp, good for perhaps 10 watts output, by using a schematic for an 807 SE amp. Trouble is, I've yet to find one that looks like I could build it. That is, simple and not requiring expensive components. I have also read comments that a schematic for a 6L6 would probably work.
So I'm soliciting opinions at this time. I have not committed on any particular course of action, and I'd have to pick up a couple parts anyway (like top caps for the anode) before I could build anything. But if you have a link to a nice, basic, no-frills, SE schematic for an 807 or 6L6 that would work with this RCA 6146B tube, I would sincerely appreciate seeing it. I have googled left right and center, but nothing has really seemed to jump out at me; perhaps I am missing something basic in my searching.
Also, if I am making some unwise assumptions or missing some dreadful bit information, please let me know that as well! I am very much the basic newbie at this.
Thanks ahead of time!
Old 23rd January 2015, 08:08 PM   #2
hooman is offline hooman  Iran
hooman's Avatar
1625 is chip and nice sound .why 6146?
Old 23rd January 2015, 08:16 PM   #3
I have an RCA PA amp that uses 6146A's which I rebuilt,,, don't think I'd build anything using them,,, but if you already have em!!!!!
I'm building an amp with 811A's,,, so, I guess anything is possible!.... I couldn't help you with a schem, tho,,, The RCA uses 0C3 regulators for teh screens, and I believe 580V Vp, IIRC,,, but thats 70W PP...
Be interested in what you come up with, I'm sure you can get help here...
Good luck...
John
Old 23rd January 2015, 08:40 PM   #4
Because I have two 6146B tubes, so I would like to use them.
Old 23rd January 2015, 09:07 PM   #5
hooman's Avatar
Old 23rd January 2015, 10:04 PM   #6
expert in tautology
bear's Avatar
Sell them to a ham radio operator who can use them.
Get some tubes that are actually useful for SE operation.
With a minimal amount of effort you can come up with not very expensive tubes.
The output iron is far more important to the final result and also likely more expensive than the lower cost tubes that are suitable for SE operation.
The chinese tubes and russian tubes are really not terribly expensive, for example EH300b work nicely and are not particularly pricey.
Given all the work and effort required to build an amp from scratch, one might as aim higher than just "what's in the junk box". Unless you have a junk box that is more like a surplus store...
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- [...2SJ74 Toshiba bogus asian parts - beware! ]
Old 23rd January 2015, 10:09 PM   #7
I have quite a few fun tubes of various sorts, and I am amusing myself building small amplifiers with them on weekends. Sometimes I like the results and sometimes I do not, but I am learning a lot. I generally disassemble when I am done and move to the next set of tubes, although some I am planning to put into a chassis at some point.
I know some folks who climb mountains. I have no idea why they would do such a thing, when we have perfectly good cars and helicopters to take them to the top if that is their goal. Perhaps they climb because that's what they want to do, rather than simply getting to a destination? Consider me a climber, then, rather than one with a goal in mind. It is less "I want to build a great amplifier" and more "I want to try to build an amplifier with these tubes for the joy of the challenge."
Humor me, if you would be so kind. I am quite aware that there are better ways to do it, but that does not mean it should not be done. Sometimes it is fun to do something off the beaten track simply for the sake of doing it.
...And FYI, the EH300b tubes you mention are very nice, and 'pricey' is a relative term. Certainly they *are* pricey by my means. I spent less than 2 US dollars on these 6146B tubes. I sincerely doubt I could obtain a pair of EH300b for 2 dollars.
Old 23rd January 2015, 11:13 PM   #8
tubelab.com's Avatar
I was under the impression that the 6146 tubes were not really suitable for SE operation. I have been known to "test" tubes at their limits and run them in unintended applications, but I have never tried the 6146 in SE.....But there is someone who has. A ham radio guy has stuffed more unusual tubes in his SSE board than I have. See this thread.
6146 in the Simple SE
Note:
Way back in 1969 I had an old Emerson color TV. The 6CB5 horizontal sweep tube was dead, and I didn't have one, so I wired in a 6146A and it worked fine. The 6146 works more like a sweep tube that a 6L6 type. Do not feed 300 volts or more into the screen grid, or your amps will blow up just like the old Ampeg SVT's did.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 23rd January 2015, 11:17 PM   #9
Note:
Thank you, I'll read that thread very carefully. Somehow I missed it when I was googling for circuits.
6v6 vs. 6l6 vs. 807 soundwise.. Ryssen Tubes / Valves 92 13th May 2014 08:05 PM
adapter to go from 6L6 to 807 Original Burnedfingers Tubes / Valves 5 23rd January 2012 12:20 PM
6L6/807 AB2 triode-- screen drive? Matt BH Tubes / Valves 2 13th October 2011 03:03 AM
What is grid resistance of 807/6l6 in pentode ryuji Tubes / Valves 9 4th May 2011 10:52 AM
807/350B/6L6 PP amps PSU ? coresta Tubes / Valves 7 3rd April 2008 09:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
