Valve Monoblocks - am I being realistic? - diyAudio
Old 22nd January 2015, 05:30 PM   #1
KarlD is offline KarlD  United Kingdom
Default Valve Monoblocks - am I being realistic?
Hi all,
I have a hunger for valves. I dream of mono blocks. I need these things in my life.
Physically constructing an amplifier would not be a problem for me - I have experience with electrical and electronic circuits, high voltages (lots of 3 phase, huge relay circuits for old school automated machinery etc), can solder well etc.
However the theory side of it is a serious problem. I have a fair knowledge of what various components do, basic electronic principles etc, but I am not for one second going to pretend that I have even approaching the knowledge required to design or modify the design of an amplifier. Getting a load of books and attempting to learn about the subject is not an option. I do not have the study ethic/discipline. It would kill it for me. I am not an academic type. I am very much hands on.
But does that mean I can't build?
There must be tried and tested schematics out there that would allow me to build a high quality circuit? One where parts are not impossibly difficult to obtain or one that leaves too many open ends to the design?
I don't have any issue with ploughing a decent amount of time and money into a project like this if it can yield results.
The alternative is to go out and buy something like an integrated valve amp such as a used Puresound 2A3 for £1200. That's the kind of performance level I want
Am I being overly ambitious? Nieve? Stupid?
Too vague?
Cheers.
Old 22nd January 2015, 05:40 PM   #2
Let me tell you a story. Not necessarily one full of common sense and rationality.
I work in a sector which is very very far away from electronics. Never had a proper electronic/electric or even technical education.
So here I am in 2011 wanting to build something for my girlfriend. She plays bass so.....I chose a valve amplifier.
Fine. Read for 2 weeks straight then took the plunge and went for Pmillet's engineer's amp. Got the parts, soldered, debugged it and....it worked!
I was hooked. Next came a large 1000w per channel ab2 amplifier based on gu81m. It works
Now I built a gu46 amplifier for my current girlfriend and am finishing up a gm100 SET stereo amplifier.
I say take the plunge. Be safe, try a pcb based project first and then be on your way.
cheers
Old 22nd January 2015, 05:43 PM   #3
kmtang is offline kmtang  Canada
kmtang's Avatar
Hey Carl,
I think the first question would be whether you want Push Pull or Single End.
Monos is the dream of DIYers.
Johnny
Old 22nd January 2015, 05:46 PM   #4
Push-pull KT88 class A amp with "universal" driver PCB
and
Tubelab SE Board | Tubelab
check these out
Old 22nd January 2015, 06:20 PM   #5
sporc is offline sporc  United States
Originally Posted by ClassZ View Post
The Uniamp is a good beginners project that sounds excellent. I've used Pete's pcb and built point-to-point having no electronics background.
Old 22nd January 2015, 06:36 PM   #6
wow!
no background and in a period of 4 years going from zero to building with these monster tubes. Congratulations! And, do you have some pictures for us? Or have I missed those?
Cheers, Erik
cheers
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 22nd January 2015, 08:54 PM   #7
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
When I am asked to build super Hi Fi valve amplifiers, after requesting the clients specification the second question is about the depth of his or her pockets! Then I determine the type of valve to build it around, EL84, EL32, KT66, EL34, 6L6WGC, 6550/KT88, 2A3, 807, 813 etc. The design is academic.
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 22nd January 2015, 09:32 PM   #8
30W Push Pull amplifier designed by Claus Byrith, Royal Academy of Music in Aarhus, Denmark. | Lundahl Transformers
The iron doesn't have to be Lundahl, just suitable, not hard to source.
Hard to find a better documented (or just better) modern valve amplifier.
rgds, sreten.
There is nothing more practical than a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 22nd January 2015, 09:48 PM   #9
Old 22nd January 2015, 09:52 PM   #10
How much power do you want? You might tell us the rationale, room size, speaker type and efficiency, how loud you like it...
Now I am Become Death, the Destroyer of Words
Short wave Valve transmittor :) what valve is best? sco1t Everything Else 89 23rd November 2012 08:42 PM
realistic minimus 3.5 transaluminum Full Range 0 8th January 2010 09:42 PM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 12:15 PM
Realistic Minimus-7 how to Zaffer Multi-Way 21 14th September 2009 05:51 PM
Is this realistic? troyhenson Subwoofers 16 9th January 2006 10:36 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
