Hi FulingThos output transformers looks nice and big!
Yes it's 7.5K 75W.I intend use it on next pentode connection 813 SE amp.
Hi Hugh
Thank you.It possess 12W's output power ,20Hz-20KHz -1dB@1W.I like the sound very much.
Hi Peleus
Thank you.I use Doubly 'C'chock.Like this.
Hi Fuling
I can't find PC86 and 6S19 in china.But the 813 pentode connection not need such tall drive tension .PC86 DC-coupled to 6S19, IT coupled to 813.
Thanks! Wd40!
I may not say quite clearly about the dangeous of using chock in 1000V sisuation. What I mean is using chock in such high voltage might short inner the chock in some time, thats my friend told me! Especially using LCLC structure. That is why I am interested the chock Wd40 used.
In Taiwan, I nearly could not find double C chocks, but EI form chocks is quite easily got!
Cheers!
Cheers!
Hi! Wd40,
This morning, I contact with the freind I mentioned in early reply.
He told me one guy in Taipei made a 845 with B+ 1000V, then, a couple of days, the chock he used got buring and short!
I don't understand the words Jax suggested that "to let the choke float by insulating it from the chassis". What that mean?
If you mount a choke the normal way then the core of the choke will be connected to the chassis and that is normally grounded. Thus there will be a potential of 1000V between the winding and the core. This might be too much for the insulation.
If you let the core float it will adopt a potential near 1000V through the leakage capacitance between the winding and the core. This will reduce the risk of an arc between the winding and core. But the choke must be installed in such a way that you cannot touch it when in operation.
- Tubes / Valves
- Progress of my 813 SE
