Progress of my 813 SE
Old 25th January 2004, 10:15 AM   #1
Jax is offline Jax  Sweden
Default Progress of my 813 SE
I'm pondering about the input stage of my 813 SE project. I need some 50V RMS with low impedance on the 813 grid. Others seem to go the single stage with a high current pentode but I would like to have triodes only. So it has to have 2 stages.
Below is what I came up with after a couple of glasses white wine. I'm probably crazy but simulation shows good result, it can drive a load of 30k in parallel with 1000pF way beyond 20 kHz and 100Vpp. Power supply is +-200V.
Am I completely nuts, or?
Jan
Old 25th January 2004, 11:33 AM   #2
Fuling is offline Fuling  Sweden
Ah, fler i detta avlånga land som håller på med 813 SE!!
My idea for an 813SE amp is as follows:
PC86 - DC-couping - 6C19 - Lundahl IT - 813 - Hammond 1628SE
Just a thought: Since your´re using a +- supply, maybe you can get rid of the coupling cap?
Old 25th January 2004, 11:55 AM   #3
It's possible to get rid of the coupling cap to the 813 if I use -300-350V but that would complicate the power supply.
Getting rid of the other coupling cap is also possible but I would have to set the grid to +85V on V2B and this baby is asked to swing 100Vpp. So I would need more + voltage, say +300V.
That would set V2B to +300V plate and -80V cathode, a bit much for the poor tube
Lowering V1A plate to -88V would only move the coupling cap to the input.
Jan
Old 25th January 2004, 11:59 AM   #4
As I said it was just a thought, I didn´t look very close at the schematic.
Whats parts are you using around the 813? (Power transformer, OPT, rectifiers etc)
Old 25th January 2004, 12:16 PM   #5
Power:
From my junk box, two 685VAC transformers for 900VDC, a lot of different chokes. Somewhere I have a couple of junk 350-0-350VAC transformers for the +-200V supply. 6SN7 needs a 6.3V biased to around -100V so may need an extra 6.3VAC.
Need: 10VAC 5A for each 813. Perhaps rewind a couple of 80VA toroids.
I'm thinking of letting Sowter wind me a couple of boatanchors for output. 8.5k primary, 8 ohm secondary, their P-sized core, it will handle 20W at 25Hz with 90mA DC. Same core can go to 20W at 20Hz if I reduce primary to 6.5k.
this project is definitely not for the newbies!
Jan
Old 25th January 2004, 01:02 PM   #6
Interresting! Let me know if you´re going to buy anything from Sowther, I might be interrested in a similar pair of OPT´s. Maybe we could save some shipping costs.
Newbies?? Definitely not! These power supplys could probably kill an elephant! It´s sad that 813´s has plate caps.
Old 25th January 2004, 01:55 PM   #7
slowmotion is offline slowmotion  Norway
slowmotion's Avatar
Hi all,
I like plate caps
I use a 10y to drive the 813, works for me
cheers, Jan
- Jan -
Old 25th January 2004, 02:21 PM   #8
Plae caps look really cool, but at ~900V they might be a bit hazardous. Not much of a problem for me though (knock on wood), since I live alone without kids or pets or anything.
If i had kids I´d think twice about using these tubes
Old 27th January 2004, 06:47 PM   #9
Bandersnatch is offline Bandersnatch  United States
Hey-Hey!!!,
I have a small boy, and I am gathering parts for a U-L connected PP 813. Look to another industry specializing in protection. Toddlers and Firearms comes to mind. I am going for ~700 B+ and those top caps make me nervous too. I am thinking some sort of lock and key for the AC power supply and then still excercise caution. Let's see, maybe one of those cool key type switches the moovies always portray the Nuclear weapons with...
regards,
Douglas
As to voltage being lethal, when backed by a few uF of high quality capacitor, it is ridiculously unsafe at voltages usually associated with SE EL84's.
the Tnuctipun will return
Old 27th January 2004, 06:59 PM   #10
Rememer to put some bleeder resistor in the PSU to discharge the caps.
OR, why not put some kind of cage over the tubes?
Progress of my 813 SEHide this!Advertise here!
in progress Jean-Paul_2 Tubes / Valves 8 12th June 2009 03:54 PM
845 - Progress so far Rob11966 Tubes / Valves 42 18th April 2009 02:02 AM
My GC progress - with pix! poeee Chip Amps 0 9th January 2005 03:38 AM
More Zen IV Progress kilowattski Pass Labs 4 26th March 2004 01:24 AM
Progress so far Kilowatt Solid State 2 15th August 2002 09:50 PM
Copyright ©1999-2017 diyAudio
