Aikido 12VAC Help needed - diyAudio
Old 9th January 2015, 12:57 AM   #1
iNSuL is offline iNSuL  United States
Default Aikido 12VAC Help needed
For anyone who has built it, what is the value of C1? I dont see it listed in the manual.
Old 9th January 2015, 01:07 AM   #2
rayma is offline rayma  United States
There doesn't seem to be a C1, do you mean C11? That would be several 10s of uF.
Old 9th January 2015, 01:14 AM   #3
On the posted schematic C1 sits between R12 and R10. In parallel to C11 and C2
Old 9th January 2015, 01:28 AM   #4
Oh yes, that's the hum canceling circuit for the current sources. It passes hum from the B+ to the two grids through the resistor divider.
The C1 should set a corner of 5Hz or less (so as not to cause too much phase shift at the hum frequencies) with the series sum of R13 and the resistor below it.
That resistor is misnumbered as R10. It is not the same value as the two R10 grid stoppers.
Old 9th January 2015, 01:29 AM   #5
Smoke is offline Smoke  Canada
.1-1 uf according to the other designs
Old 9th January 2015, 01:34 AM   #6
The capacitor value depends on the resistors that it feeds.
Old 9th January 2015, 01:39 AM   #7
So the values are R11-1k and R10-88.7k
Old 9th January 2015, 01:46 AM   #8
How do I go about calculating the value based off the resistors? Thanks for all your input
Old 9th January 2015, 01:50 AM   #9
You need to know the two resistors directly below the C1, which are labeled R10 and R13. (That R10 is not the same value as the R10s on the grids, it's a numbering mistake.) Add the R10 and R13, and then set the capacitor C1 value so the corner is below 10 Hz. C1 = 1 / ( 2 x 3.14 x 10 x ( R10 + R13 ) )
Old 9th January 2015, 01:54 AM   #10
Awesome, thank you so much for the help!!
Aikido 12Vac yakusa Tubes / Valves 34 27th January 2016 08:32 PM
Aikido 12vac cbutterworth Tubes / Valves 9 25th January 2015 12:45 AM
aikido 12vac help needed shine20 Tubes / Valves 4 19th June 2014 02:03 AM
hifimediy t2 - Aikido 12vac shine20 Class D 0 22nd April 2014 04:51 PM
LM3875 (Audio sector) + Aikido 12VAC or Aikido ACF-2? Sodacose Chip Amps 30 28th August 2013 09:28 PM
Copyright 1999-2017 diyAudio
