2A3 input sensitivity - diyAudio
Old 28th December 2014, 12:15 PM   #1
Vidre is offline Vidre  Spain
Default 2A3 input sensitivity
Hi everybody.
Does anyone know the input sensitivity of an amplifier type Loftin-White 2A3 Single-Ended Triode (with 6SL7)?
Old 28th December 2014, 08:14 PM   #2
THD+N is offline THD+N  United States
If you use the "original" circuit as a reference and the cathode resistor is bypassed with a cap, then the input sensitivity of the amp will be approximately 1VRMS for 3.5 Watts out at 5% THD+N.
Many factors come into play here, but that is a good estimate based on a few 2A3 amps I have built using a 6SL7 tube as a driver.
Old 28th December 2014, 11:55 PM   #3
It is difficult to address your question without a schematic, and I am not attempting to disagree with TDH+N; but, in my estimation, it is difficult to obtain much more than 3 Watts out of a 2A3 into a reasonable OPT impedance...especially in your typical Loftin-White circuit.
Assuming a plate load equal to 200% of the 6SL7's R(p), and a fully bypassed R(k), I'm guesstimating that 1.3 vac input will give you approx 3 Watts into a 3k5 load.
Last edited by dowdylama; 29th December 2014 at 12:13 AM. Reason: corrected spelling
Old 29th December 2014, 12:05 AM   #4
Power output will also depend on the output tube used. I am using Sovtek 2A3's and there appear to be very robust (And sound fairly good to me) and you can drive them harder than NOS 2A3's.
Check out the 2A3 schematic I just posted.
Old 29th December 2014, 11:13 AM   #5
I will seek the schematic. Thanks for the replies.
What is input sensitivity? boxedin Solid State 17 28th January 2013 09:58 AM
input sensitivity? adrianc Solid State 17 1st April 2008 06:40 AM
Input sensitivity keyser Solid State 6 19th February 2005 03:08 PM
Input Sensitivity StefanJ83 Everything Else 1 20th November 2001 10:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
