Old 25th January 2004, 11:52 AM   #11
Morse is offline Morse  United States
Hi EC8010, Sy;
I like the ideas I've seen so far for cutting back on the turnon thump. Here are a couple of other suggestions for helping Morfeas improve his amp (not just turnon thump); what does everyone think of them?
1. Put the smaller cap first in that CLC bridge - maybe even add a smaller first leg to his CLC filter just to take it easy on his PS trafo. Charging those enormous HV caps has got to be stressing his trafo!
2. Put an NTC (Negative Temperature Coefficient) thermistor inline with the B+ (in front of the caps) to help limit the current flow.
3. Drop the size of the filter caps and rely more on inductance to provide filtering.
4. Use a hybrid or indirectly heated valve rectifier instead of ss - obviously this won't work with the enormous current draw of those caps at startup. A 5AR4 has a textbook max lead cap size of 40uF IIRC, for example - I'd keep it under 30uF personally.
Just ideas. Good luck Morfeas!
All the best,
Morse
Old 25th January 2004, 12:27 PM   #12
morfeas is offline morfeas  Greece
@EC8010: hope so. I didn’t get that big bang at the lab with 89db speaker. But my main speakers are 100db.
@Sch3mat1c: ìF (microfarad)
@SY: unfortunately the PT is one. So I’m going to try it on the secondary AC HV line.
@Morse: there is a thermistor on the primary of the PT. PT is 630VA. No space available on the chassis for an extra tube.
Thanks to all for the replies.
Old 25th January 2004, 01:30 PM   #13
SY's Avatar
It's best to use the current limiter on the primary side. They don't tend to like high voltages. If it causes the filaments to warm a bit more slowly, that's probably OK (that's the way Eico did it in some of their classic tube amps with SS rectification). The main thing is to not do the sort of hot switching you've got set up now.
If there's a sucker born every minute, where do the rest of them come from?
Old 1st February 2004, 08:37 AM   #14
Default All OK
Problem solved.
Moved the relay just after the bridge with 4k7 in parallel.
Thanks to all.
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
Hum and Noise with Ono rsbay Pass Labs 0 26th February 2006 12:51 PM
NOISE - RFI and EMI jackinnj Everything Else 9 26th February 2005 01:01 PM
Noise Bukitoo Analogue Source 2 17th March 2004 02:37 PM
DSP and DAC noise nFORCE Digital Source 4 29th April 2003 03:18 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
