diyAudio Sponsor
Old 22nd January 2004, 11:42 PM   #1
GAK is offline GAK
Default voltage regulators
Hi
Any source for tube based voltage regulators?
I'm planning to build a phono-line stage with a tube voltage regulator.
let's boom chitty boom
Old 22nd January 2004, 11:49 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Shunt or series?
Frank
Old 23rd January 2004, 05:07 AM   #3
jackinnj's Avatar
you'll find the old designs in the ARRL Handbook from the 1960's. Email me privately if you want a copy.
You would be much better off using a pair of IRF HexFET's -- unless you like to ke your room warm with tube-based regulators.
Old 23rd January 2004, 08:22 AM   #4
marz.tv is offline marz.tv  Sweden
marz.tv's Avatar
I think is a good idea to keep it all tube. For low current applications, the filamentless 0A2 (150v, Imax 35ma) and 0B2 (108v, same Imax) are easy to start with. And the purple glow is just wonderful! ^^
You can also put them in series for different voltages. They are used as shunt regulators after the B+ is rectified and filtered, with a resistor just before to set the voltage drop (from the current draw of the regulator tube plus the audio circuit).
They need a little higher voltage to 'strike' or start up, 185v for 0A2 and 133v for 0B2, so make sure that the transformer delivers at least this much HV.
What tubes are in your phono amp?
Russ Sadd's homepage is apparently down for now, but I think he used to have a very good walkthrough on regulated tube supplys.
Good luck!
Old 23rd January 2004, 12:30 PM   #5
jackinnj's Avatar
Steve Bench has a tutorial on his site:
members.aol.com/sbench/reg5.html
there were also some designs at tubecad
Old 23rd January 2004, 12:59 PM   #6
dibbi is offline dibbi  United Kingdom
There is a kit available here
http://www.transcendentsound.com/tube_power_supply.htm
Old 24th January 2004, 03:15 PM   #7
GAK is offline GAK
I have read Steve Bench articles.They're very nice.
Maybe I'll build something from his ideas.
In part 3 has a very good design.
About the tubes in phono I haven't decided yet.
I'm thinking to use ECC82-81 in SRPP configuration.
Two srpp and the riaa filter in the middle.A classic design.
An other idea is with 5692 (if I remember right).
I saw a design in audioXpress magazine.
If anyone has a good schem in mind is acceptable.
The line stage will be with the 12B4A.One triode per channel.I have build it in an experimental mode and I'm listening with it in my system right now and I'm very satisfied.
Old 24th January 2004, 04:10 PM   #8
analog_sa's Avatar
The 12B4 line is a good idea but i am not so sure about the ECC81-82. Never heard commercial or diy phono using these tubes that sounded halfway decent. Even the ECC88 is a better bet.
Old 24th January 2004, 04:35 PM   #9
GAK is offline GAK
Hi analog_sa
Which tubes do you suggest is a good idea?
Any good schem?
Old 24th January 2004, 10:09 PM   #10
jackinnj's Avatar
this link to the 1964 article from the ARRL handbook on tube regulation will be up for a couple days, then I will take it down:
http://www.tech-diy.com/tuberegulation.pdf
Low Noise 3 Leg Voltage Regulators dsavitsk Parts 2 10th July 2007 03:49 AM
Pre amp voltage regulators help. AMV8 Solid State 19 6th April 2007 10:30 PM
voltage regulators odysseybmx414 Chip Amps 23 2nd January 2006 09:35 PM
voltage regulators NAP 160 Digital Source 7 11th August 2002 10:14 PM
Discrete voltage regulators. JoeBob Solid State 1 18th March 2002 06:25 AM
Page generated in 3.56160 seconds (-0.01% PHP - 100.01% MySQL) with 10 queries
