Two-cases amplifier, question about power switch - diyAudio
Old 3rd December 2014, 05:40 PM   #1
00940 is offline 00940  Belgium
Default Two-cases amplifier, question about power switch
Just a small question about switches and two boxes setups...
Here's the setup: the transformer (40VA, 200vac@100ma and 8vac@2A secondaries) is in an external plastic box. There's a fuse at the entry. A lead with 4 conductors+earth goes to the amp case. The amp case is earthed.
Question is: is it unwise to use a single DPST switch (250V/3A rated) to switch both one line of the 200Vac and one wire of the 8Vac ?
Ben.
Old 3rd December 2014, 06:11 PM   #2
Rundmaus's Avatar
Yes it is unwise to mix low and high voltage circuits in a switch. Why not switch the mains before the transformer?
Rundmaus
Old 3rd December 2014, 06:13 PM   #3
transformer box is under the desk, the amp box on the desk ;-)
Ben.
Old 3rd December 2014, 06:43 PM   #4
jakubg is offline jakubg  Slovakia
I have a similar setup.
I'm bringing the live wire before transformet to the switch in the top box and back again to the transformer. Tightly twisted together, don't know if it helps.
Old 3rd December 2014, 08:31 PM   #5
mark02131's Avatar
I like to use relays and a 6v transformer (DC) in the power supply that's always on, then you have a low voltage switch in the amp that turns on the replays for the mains transfomer. You can also add another relay for "standby" that turns on/off the HT.
Then if the power supply and amp ever get disconneted the power supply shuts down becuse the relays loose the 6v on them. I would also put a mains switch on the power supply in the event you want to shut it completly off.
Old 3rd December 2014, 08:37 PM   #6
Rundmaus's Avatar
+1
Old 3rd December 2014, 08:41 PM   #7
+1, I wish... too much space constraints in there to do that.
If you think it's truly unsafe, I'll remove the switch on the amp and use a switched power bar under the desk.
Ben.
Old 22nd December 2014, 01:05 AM   #8
The solution is rather obvious now that I think of it... I just need to use the power switch to control the 8vac line to the heaters and use the heaters DC supply to control a relay that will in turn switch the B+ AC.
Ben.
Old 22nd December 2014, 01:08 AM   #9
When I had the PSU on the floor, I just used my foot to toggle the switch!
Power Switch Question kstylianos Parts 2 8th June 2012 03:04 PM
Simple Power Switch Question Littlebilly91 Construction Tips 7 29th April 2012 12:27 AM
On/Off Power switch question madisonears Chip Amps 6 29th March 2009 02:36 PM
Newbie question on power switch senderj Parts 5 17th February 2006 10:50 AM
And now a question about power switch... mr mojo Tubes / Valves 13 16th August 2005 02:37 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
