I would think that if there was four tubes in the pre that two would be for phono (one per channel) and two for line stage (one per channel) but I not as knowledgeable as you when it comes to this kind of thing...crosstalk or channel induction through a stereo volume control as well might be an issue?...which brings in another question...to swap the balance control for a mono volume and swap the existing stereo volume for a mono like the Audible Illusions...only if I didn't care about this units originality and it might be best to leave it as isNot really sure why this is a big surprise, it was fairly commonly done. Practically speaking leakage (cross-talk) in the source selector switch and other places probably does more to degrade stereo separation than a shared tube provided some care in construction was used.
Yes its 115v out of the receptacle and hidden under a resistor welded to the the tranny input is 100v so yes I will look for a bucking tranny that will give me 100vNoticed this item on that page:
"...Amplier [sic] was manufactured for Japan so its AC electric volt is 100-110V 50/60Hz, you need step down transformer if you want to use it in 220V area."
You're in Calgary AB Canada; power there is same as here in the US, no? 117VAC nominal, perhaps as high as 125VAC. You would need a Variac, a bucking transformer, or a power-transformer replacement.
Take care,
J. E. Knox "The Victor Freak"
hmm...don't know where I got 115v the multimeter says 123.5v so according to this schematic I need a 24 volt transformer if I want 100v or 99.5v An Inexpensive Line Voltage Changer.
The 24v transformer I used to buck the voltage to this preamp was 5v shy of the 100v I was hoping to get...would a 20v tranny be the correct choice though?...I had overlooked the fact that the primary was rated at 115v not the 123.5v metered from the outlet therefore the output will be higher than 24v rated...this math should be easy?...the turns ratio is not given but if a % of volts reduced is used this should sort this out?...24/115=20.8% so 20.8% x 123.5=25.6...123.5v - 25.6 = 97.9v...hmm thats only 2v shy of 100v why am i only getting 95?...if I used a 20v tranny 20v/115v=17.4% so 17.4% x 123.5v = 21.5v...123.5 -21.5 = 102v...this should be the better choice?...however considering this preamp is 47 years old and completely point to point wired I was expecting a little disappointment...this pre surprised me...first impression was it has heaps of depth even more than the A.I. modulus 2c...gain seemed enormous like that of a live venue...makes me wonder if this pre would work with a moving coil without the step up transformer I presently use a high output MC ...vocals and symbols also seemed to soar more than the A.I. giving it a sense of presence I had not heard before...this preamp is another shining example of why a preamp is so important in a stereo...don't get me wrong I still think the A.I still has its place and it would be tough to let it go...it has a home still and has attributes that set it apart from the norm...
Buy a Variac on Ebay. You can adjust the voltage to what you need. It will also come in handy for many projects.... Mcm electronics has several to chose from.....
..this bucking tranny will be a permanent addition to this pre unless it gets sold again in japan...variac is expensive and good for an electronics workbench
I use dn2540 depletion mosfet as active loads, just needs two resistors and your off, led to bias on the cathode. Low mu small Idh Triodes are not that common but 6sn7 was popular and much more linear though you'd need an octal socket. I use 4p1l but you'd ideally need a more complicated power supply for that.
this might as well be japanese to me lol
- Tubes / Valves
- ecc82/83 questions
