help with long tail pair bandwidth - diyAudio
Old 15th November 2014, 04:05 PM   #1
Default help with long tail pair bandwidth
i have a problem with a long tail pair bandwidth
i dont know where is the problem , the amp roll off at 7khz.
help me please
Old 15th November 2014, 04:29 PM   #2
maton00 is online now maton00  Mexico
maton00's Avatar
Send a message via MSN to maton00
Why do you have C1 connected in that way?
Old 15th November 2014, 04:30 PM   #3
jane is offline jane  Norway
jane's Avatar
The 100 k gridstopper (R6) will reduce bw.
Life is hard - Then you die.
Old 15th November 2014, 04:32 PM   #4
DF96 is offline DF96  England
Miller effect in U2? 100k is quite a large value for a grid stopper, except in a guitar amp where full audio bandwidth is not a requirement and people want to be able to:
1. adjust treble response by swapping valves instead of using a tone control,
2. get away with an appalling layout wth long wires everywhere.
NB I assume C1 is to stop Miller effect in U1?
Old 15th November 2014, 04:35 PM   #5
nec3 is online now nec3  Turkey
Reduce C1 down to 1P, or delete.
Also, C2,R7 NFB network needs correction.
Old 15th November 2014, 05:56 PM   #6
Removing C1 will narrow the bandwidth further, by introducing Miller effect in U1. "1P" I assume should be 1pF? I can't see any R7 or NFB.
Old 15th November 2014, 06:08 PM   #7
Well even though I had a good laugh at this, I don't know of any guitar players who swap valves to adjust treble response.........must be a British thing?
+1 on the long wires and crappy layout though
Old 15th November 2014, 06:22 PM   #8
C1 10uf is too high.
C2, R7 are in asc. file.
Edit: Q2 has a Vce voltage 149v. Spice model of BC547 is defined with a 50V max. I have no idea how LTspice response this though.
Old 15th November 2014, 06:27 PM   #9
kevinkr's Avatar
V3 does not need to be more than about -12V. If you build the circuit consider using a cascode CCS with DN2540.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 15th November 2014, 07:18 PM   #10
Merlinb is online now Merlinb  United Kingdom
Merlinb's Avatar
The problem is R1, not C1. This is a cathode-coupled amplifier, not a phase splitter. Reduce R1.
How to bias Long tail pair....?? RRITESH Solid State 85 4th September 2014 09:30 PM
Long Tail Pair mr2racer Tubes / Valves 13 11th February 2012 04:38 PM
Long Tail Pair Linearizer Electrone Solid State 17 21st April 2009 03:25 PM
5687 long tail pair NickC Tubes / Valves 7 14th May 2002 02:04 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
