First build- dual mono octal linestage - diyAudio
Old 14th November 2014, 02:40 PM   #1
Default First build- dual mono octal linestage
Hello everyone. This is my first go at building a tube based preamp. I decided to go with the aikido and attemp a completely dual mono design with tubes for outputs and power supply.
My first idea was to have dual mono octal with a dual PS-4 power supply and separate transformers. I have been looking at the Janus shunt regulator as and option although it would not be a true separate system. I do not not know enough to decide what would be better or if I really need a dual power supply. One question I do have is about the shunt regulator being dependent on input voltage and could potentially vary in output voltage. Would this matter in a line stage? Would the Janus provide a lower noise floor?
Another question was if I go with the Janus would I benefit from a separate line and heater supply or is one with separate windings plenty. If I do end up going completely separate I am thinking a couple hammonds would do the trick.
Again i am totally new to buidling a preamp from scratch. I have spent a lot of time trying to read up but would appreciate any resources one might have to further my understanding. Thanks for the help
Old 16th November 2014, 02:46 AM   #2
Bump...
Any help? Main question is about getting a good power supply
Old 16th November 2014, 03:30 AM   #3
rayma is offline rayma  United States
Originally Posted by mjstriker5 View Post
Bump...
Is this a line amp, or does it include a phono circuit? It might be interesting for you to try several types
of power supplies and see if there are audible differences.
Old 16th November 2014, 02:09 PM   #4
This will he a line amp.
Was thinking the same thing about several power supplies. Thinking I can get the Janus pcb and could make the PS-4 power supply from the given schematic.
In the end it will be about just experimenting.
Any thoughts on a choke? Separate power supplies for the heater/output? Initially was thinking a separate supply for each channel but now I think just separating the heater output would be best
Old 16th November 2014, 04:37 PM   #5
If you have dual mono audio circuits, it'd be a shame not to go dual mono power supply.
Old 16th November 2014, 05:45 PM   #6
Exactly what I was thinking would I benefit from dual transformers (1 for each power supply or just separate the line and heater voltage?)
The schematic for the PS-4 power supply seems pretty straightforward to wire point to point. That was th initial plan. Then I looked at that Janus shunt regulator and thought that would be better but wasn't to sure how to wire it up (specifically the tubes)
I guess I could get one Janus and use it as a template to do my P2P.
I'll post the schematics and maybe someone can help
First build, Dual-Mono LM3875 AlexQS Chip Amps 56 1st April 2012 11:40 PM
Planning to build an Aleph 5 dual mono amps - advice commandercam Pass Labs 1 20th October 2009 12:04 PM
FS Aikido Octal linestage $75 nvrgdenuf Swap Meet 2 29th December 2008 09:35 PM
Mikaels KT88SE & VTV Octal Linestage AKlein Tubes / Valves 17 10th June 2008 04:16 AM
AudioSector LM4780 Dual-Mono - questions/build log gongzero Chip Amps 3 22nd October 2006 03:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
