Mono series attenuators vs. PEC for balance control? - diyAudio
Old 7th November 2014, 04:46 PM   #1
greg7 is offline greg7  United States
Default Mono series attenuators vs. PEC for balance control?
The Tubes4hifi Aikido preamp I'm building comes with a pair of mono 23-step series attenuators, one per channel, for balance control. They can also set overall gain. They come pre-assembled with inexpensive (Vishay-Dale, Xicon?) metal film resistors.
Sonically, am I better off using the stepped attenuators (which have the benefit of discrete steps for precise matching) or a pair of mono PEC series K potentiometers?
I will use these rather than set them at max because I do have a slight stereo image imbalance in my room, plus I may need to lower overall gain. So it becomes a question of which sounds better -- signal going through a couple or even several cheap metal films versus signal going through carbon potentiometers
DACT Mono 100k Attenuators for sale driguy Swap Meet 0 28th September 2012 12:01 AM
LDR attenuators - Better balance with DC bias godfrey Analog Line Level 33 1st April 2012 05:13 PM
FS: DACT Stepped Attenuators & Balance Control enjoythemusic1 Swap Meet 9 29th September 2011 01:44 PM
FS - (2) Goldpoint Mono Custom Attenuators Guiness Swap Meet 0 11th December 2010 12:49 AM
Source for PEC mono attenuators? Colescuttle Chip Amps 3 2nd January 2007 12:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
