Is 5 Watts enough? - diyAudio
Old 6th November 2014, 06:51 PM   #1
Default Is 5 Watts enough?
I was planning to pick up a Inspire EL84 amplifier to power my B&W 640i.
My room is relatively small but I like to listen to music pretty loud. I also watch movies with these. Right now they are hooked up to a cheap 20 watt tripath amplifier. The speakers are rated at 4 ohm nominal Impendance and 91db spl(2.83V 1m).
Would the 5 watt Inspire EL84 satisfy my needs?
Old 6th November 2014, 07:03 PM   #2
Mooly's Avatar
Five watts can be louder than you think.
Try this to get an idea,
A Test. How much Voltage (power) do your speakers need?
Installing and using LTspice. From beginner to advanced.
Old 6th November 2014, 07:06 PM   #3
artosalo's Avatar
Originally Posted by VolumexD View Post
...The speakers are rated at 4 ohm nominal Impendance and 91db spl(2.83V 1m).
Your speaker specs is a bit odd. 2,83 V to 4 ohms is 2 watts.
Isn't the the sensitivity usually specified at 1 watt ?
5 watts produce 4 dB more sound pressure than 2 watts, i.e. 95 dB spl.
Old 6th November 2014, 07:15 PM   #4
aardvarkash10's Avatar
I'm picking the speaker has a pretty vertiginous impedance curve that would decimate any hope of an EL84 amp providing reasonable drive.
Power may not be a problem - impedance match will be.
"Folks, you can't prove truthiness with information. You prove truthiness with more truthiness. In a process known as truthinessiness." - Stephen Colbert, The Colbert Report
Old 6th November 2014, 07:15 PM   #5
Ripped right out of the B&W website. DM640i
46Hz – 20kHz ± 2dB on reference axis
91dB spl(2.83V 1m)
4 ohms
30W – 200W into 4 ohms on
undistorted speech and music
programme
Old 6th November 2014, 07:23 PM   #6
IMO/IME it is highly unlikely that a 5 WPC tube amp will prove satisfactory, when mated to the B&W speakers. The "true" sensitivity of the speakers is 88 dB., as 2.83 V. into 4 ohms is 2 W., not 1 W. Paul Joppa's 102 dB. rule suggests you need a minimum of 32 WPC.
I would not mate the B&W speakers to tubed power amplification, except for a Harman/Kardon Citation II, which (for a tube amp) has a gargantuan damping factor. The "Deuce" works very well with AR-3s and AR-9s, which (I suspect) have much in common with the B&Ws.
Eli D.
Old 6th November 2014, 07:26 PM   #7
artosalo's Avatar
Then the sensitivity of your speaker is 3 dB less than a 8 ohms speker with 91dB spl (at 2.83V 1m), but this may not be any problem.
Old 6th November 2014, 08:05 PM   #8
azazello's Avatar
SE EL84 will give You 4-5 Wt with distortions. For Your 90 dB speakers is suitable PP EL84 /12 Wt/ or more cheep PP ECL /PCL/82 or 86 /8-10 Wt/, only two tubes per channel, instead 3 or 4 tubes per ch. in PP EL84. You can find the treads with schematics on the forum. I'd like advice You.
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 6th November 2014, 08:12 PM   #9
BigE is offline BigE  Canada
I would not make that pairing. Is this a setup you already own or considering buying?
Old 6th November 2014, 08:23 PM   #10
azazello's Avatar
PHILIPS H4F 74 A/01 / ECL82 / 6BM8
"En sa Fonction PP delivrant 10 Wt" - this schematic. You can add input poti 50-100kohm. PS is next schem.
ucd 25 watts to 1200 watts using 2 mosfets andrewlebon Class D 3899 4th November 2014 07:59 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
watts vs watts Hayden Parts 7 30th July 2006 01:57 AM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
