Vacuum Tube Workshop
Old 27th October 2014, 10:26 PM   #1
George Schmermund is offline George Schmermund  United States
Default Vacuum Tube Workshop
Well, it looks as though the workshop is going to become a reality! Much progress has been made since my last posting. I'll keep you up to date as progress continues.
Here's a link: Home
Old 27th October 2014, 10:49 PM   #2
On Hiatus
SY's Avatar
This is extremely cool!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th October 2014, 11:04 PM   #3
Soothsayerman is offline Soothsayerman  United States
Soothsayerman's Avatar
Here's a link: Home
Props!! Very Cool! Best of luck with this!
Old 27th October 2014, 11:30 PM   #4
kevinkr's Avatar
Yes, very cool. Would be fun to take the workshop..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th October 2014, 11:35 PM   #5
blueglow is offline blueglow  United States
blueglow's Avatar
Tell me more, what's the workshop all about?
Old 27th October 2014, 11:41 PM   #6
famousmockingbird is offline famousmockingbird  United States
"I have all of the equipment and materials needed to do the job properly and can transfer the necessary skills to anyone who is at least capable of replacing a screw on a pair of hindged eye glasses"
I should be all set then.......as long as dropping and losing the tiny screw a hundred times is all right
Old 27th October 2014, 11:51 PM   #7
overtheairbroadcast is offline overtheairbroadcast  Canada
America gets all the neatest stuff. Very cool and congratulations!
Old 28th October 2014, 12:29 AM   #8
The workshop will be held sometime in the first quarter of 2015 at the Joe Martin Foundation Craftsmanship Museum located in Carlsbad, CA.
The Director of the museum, Craig Libuse, has generously offered to host the workshop on a Monday, which is normally a closed day for the museum. A section of the machine shop has been allocated for the project.
Included in the workshop will be all of the tools and supplies needed to build and process a simple vacuum pliotron. Also included will be an Armstrong regenerative radio kit designed to cover the AM broadcast band. This kit will be assembled by you during your tube's vacuum bakeout. The radio will be a good way to show off your craftsmanship!
Each tube will be tested on a curve tracer and a hardcopy set of its characteristic curves will be plotted.
Old 28th October 2014, 03:47 PM   #9
nosbor is offline nosbor  United States
Shoot, I live in Poway and work at the split. This should be fun.
Old 29th October 2014, 05:10 AM   #10
devilsindetails is offline devilsindetails  Canada
devilsindetails's Avatar
Wow!
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Vacuum Tube WorkshopHide this!Advertise here!
6n2 + fu32 vacuum tube tube headphone amplifier jhin Headphone Systems 1 12th November 2013 03:23 AM
exactly HOW does a tube amp work? or a vacuum tube? realflow100 Tubes / Valves 27 25th September 2012 03:17 AM
Vacuum tubes, vacuum capacitors and vacuum relays GREENSTONE USA Vendor's Bazaar 0 19th August 2011 03:38 PM
Homemade Vacuum Tube dhaen Tubes / Valves 50 13th July 2011 05:48 PM
The Vacuum Tube Truth Serratoga Tubes / Valves 31 29th November 2007 09:25 PM
