The hardest part about a DIY tube amp is.....
Old 26th October 2014, 04:25 AM   #1
Soothsayerman is offline Soothsayerman  United States
Soothsayerman's Avatar
Default The hardest part about a DIY tube amp is.....
Finding a design to build! I have looked and looked and do not know enough about all the classics to know if an old Eico or Marantz would fill the fill, so I want to get some input. I am a tinkerer and a solder slinger but I am no designer. I wanted something that could (if possible) get by with just point to point wiring and no PCB's.
Anyone know of an amplifier that would include the following? Obviously, not everything is included here but this is in very general terms what I have been looking for.
Integrated amplifier design
Capacitor coupled
Push-pull
4 x KT88 or EL34
2 power transformers
1 psu chokes
2 anode chokes
2 Output Transformers
Pre-amp controls
- Line Input Selector - 4 sources 4 sets of RCA Inputs
- Stepped Volume Control
Speaker taps - Main L / R 8 ohm only
Old 26th October 2014, 04:30 AM   #2
iko is offline iko  Canada
iko's Avatar
Really good power supply. Period.
Old 26th October 2014, 04:42 AM   #3
MaicoDoug is offline MaicoDoug  United States
I see you have 2 Anode Chokes listed, are you considering a Balanced Parafeed design?
I love point to point construction.
The Pre-Amp design is just as important, to say the least. What kind of input are you going to use? And will this Pre-Amp be on board this chassis? Or do you already have something doing the Pre-Amp duty? Regulated Power Supply is Key. What about negative feedback, distortion %'s?
I'm exactly where you're at. And reading as much as I can.
Regards, Doug
Old 26th October 2014, 07:06 AM   #4
Andreas AVM is offline Andreas AVM  Ukraine
Capacitor coupled
Push-pull
4 x KT88 or EL34
2 psu chokes
2 anode chokes
Pre-amp controls
Good idea!
Why do I need "2 psu chokes" ?
Separate anode power - very good.
Output and power transformers have already purchased?
What the rest of the tube you wish to use?
Old 26th October 2014, 09:46 AM   #5
costis_n is offline costis_n  Greece
Originally Posted by Andreas AVM View Post
Good idea!
I am guessing it if for two monoblocks.
For the OP, keep in mind that any of designs that have global feedback, the compensation networks are for the specified output transformer only.
You need a >10Mhz scope to fine tune the compensation if you use a different output transformers
Point to point is certainly possible, maybe have a look in the Photo Gallery thread.
Old 26th October 2014, 01:59 PM   #6
Oops,
I changed it back to just 1 psu choke. It's a single chassis.
Old 26th October 2014, 04:32 PM   #7
Eli Duttman is offline Eli Duttman  United States
AMEN!
If the OP is willing to add the 7591 to the list of potential "finals", a variation on the "El Cheapo" theme is a possibility. Fisher, Scott, Sherwood ... took full advantage of the fact that small signal circuitry used with "12" W. O/P tubes requires no change to drive 7591s. Obviously, the "trick" is available to anybody that cares to use it.
FWIW, "El Cheapo" was designed so the builder needs only a decent DMM to complete the project. A brute force method of phase compensation is available. Connect a small cap. from the "hot" leg of the O/P trafo to ground. The cap. shorts the NFB loop out above a freq. of at least 80 KHz. The better the O/P "iron", the smaller the cap. becomes.
Eli D.
Old 26th October 2014, 05:24 PM   #8
Originally Posted by Andreas AVM Click the image to open in full size.
Good idea!
Thank you.
But I do not need help.
I talked to starttopic post1.
Old 26th October 2014, 06:25 PM   #9
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
The hardest part about a DIY tube amp is........ diy BOX CASING
Old 27th October 2014, 04:09 AM   #10
Thats easy, so many places that will provide enclosures or just get two plates and have a wood sides!
The hardest part about a DIY tube amp is.....Hide this!Advertise here!
DIY budget Class T/D & tube pre-amp thoughts and recommendations? JonesySA Everything Else 0 14th August 2014 03:04 AM
What types of SET rock the hardest? wixy Tubes / Valves 23 1st April 2011 03:05 AM
Musical Instrument tube amp part suppliers bastieng Tubes / Valves 2 19th July 2006 10:52 PM
Chinese Tube Amp & DIY .. Pro & Con zxx123 Tubes / Valves 6 18th January 2005 10:54 AM
what tube preamp DIY kit to match B&W P-5 speakers skydog Tubes / Valves 4 22nd January 2004 10:48 PM
Copyright ©1999-2017 diyAudio
