diyAudio Sponsor
Old 19th January 2004, 12:19 PM   #1
Brap is offline Brap  United States
Default Consonance ELLA
After many posts on another forum (Klipsch), I think I'm dialing in on the Ella amp and for now will run direct from a CD player until finances permit a nice pre-amp kit.
Questions
1) Who has experience with the Ella?
2) Upgrade to KT-88's?? (I left a message with the mfg. to ask about the bias and output transformer handling these)
3) Suggestions on a good pre-amp? Prefer a kit, but have learned the Creek OBH-12 is a nice piece for the $$. Am considering sticking with a tube pre -- possibly matching the Basie to this.
Your thoughts are appreciated
Old 19th January 2004, 11:38 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Does it have to have gain?
Frank
Old 20th January 2004, 02:00 AM   #3
mcs is offline mcs  Denmark
Default Re: Consonance ELLA
If you're considdering the Creek, have a look at this: http://stiftsbogtrykkeriet.dk/~mcs/Remote3/index.html
And also have a look at my post in "Trading Post"...
You can always convert a passive pre to an active one if you need gain or a buffer stage. If you keep the pre close to the poweramp, I think a passive should work fine. It works for me...
Best regards,
Mikkel C. Simonsen
Old 20th January 2004, 02:42 AM   #4
bcherry is offline bcherry  Hong Kong
bcherry's Avatar
Send a message via Yahoo to bcherry
Hi Brap
If you sent it to me, I didn't get it.
The Basie is not suitable as too much gain. The ideal match (although more budget is needed) would be TVC-based linestage. Or drill a couple holes and install a toggle switch and extra set of RCA jacks. There is room.
Brian
Disclaimer: I may or may not offer for sale items mentioned in this thread, and if I do, I may or may not make a profit.
Old 20th January 2004, 10:12 AM   #5
I did some work with the ella
what i did was build the stock unit for a local audio shop
built up the stock unit didn't really like it .
change to triode and remove the feedback with a reduction of power also some components mods and did some circuit optimization. Changed the el34 to eh6550 and ehkt88 with both biased at -40volts. As i recall from the curves for both of this tubes, -40 is smack into class A region and drawing lots of current.
You could feel the slight increase in power, but i prefered the eh6550 to the kt88 which i felt sounded to boomy. The el34 used was svets which sounded fine to me. Opt seems oversized for the job anyway. Work fine with kt88s into almost deep class a anyway. For gladly recommend it due to the price paid and the sound in return. Not affliciated with bcherry though. Just an honest opinion
Ella amplifier problems regralf88 Tubes / Valves 3 14th January 2009 12:12 AM
Consonance Ella Diy hifi supply, el34, 6550 or KT88? OzMikeH Tubes / Valves 16 24th February 2008 12:04 PM
Ella Valve Amp Brain Swap Meet 5 4th April 2006 05:35 AM
Ella EL34 Bias Help plepagejp Tubes / Valves 0 31st January 2006 01:08 AM
Wesnor's Ella's nOOSE Multi-Way 12 7th September 2004 11:21 AM
Page generated in 0.08446 seconds (76.32% PHP - 23.68% MySQL) with 10 queries
