strange Tungsram tube
Old 21st October 2014, 08:57 AM   #1
hoangduongo is offline hoangduongo
Default strange Tungsram tube
While looking through my collection, I found a tube with no marking other than "Tungsram h5" on it.
The tube has loktal pinout and looks like a kenotron to me.
Anyone has any idea about this tube?
Duong
Old 21st October 2014, 09:43 AM   #2
davorin is offline davorin  Croatia
AZ21 !
Old 21st October 2014, 10:05 AM   #3
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Made in March 1959 but I don't recognize it. Can you clean the glass or detrmine the type, Pentode, Tetrode etc?
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 21st October 2014, 10:44 AM   #4
100% tube is AZ21 !
Old 21st October 2014, 11:31 AM   #5
Vincent77 is offline Vincent77  Europe
Vincent77's Avatar
davorin is right, the tube is obviously a rectifier.
Old 21st October 2014, 01:15 PM   #6
My tube looks exactly the same as Davorin's.
I've googled AZ21 and indeed this is my tube.
Now I wonder what "h5" means, since there's nothing printed on the tube except what showed on the photo.
Thanks a lot,
Duong
Old 21st October 2014, 01:17 PM   #7
h5 is the date code for March 1959.
Old 21st October 2014, 01:39 PM   #8
kevinkr's Avatar
Just thought I would mention that Kenotron is an uncommon/obsolete usage in English these days, it's origins are back in the 1920s somewhere. The widely understood term would be "rectifier." The first time I ran across it here some years ago I had to look it up.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 21st October 2014, 05:08 PM   #9
Yes, in western documents those tubes are usually called rectifier, however i'm a bit more familiar with "kenotron" because I used to read Russian documents where they're called "кенотрон" which is the same as kenotron when you translate character by chracyer from Cyrillic
Also, it's really interesting that my AZ21 and Davorin's have exactly the same datecode "h5"as well.
strange Tungsram tubeHide this!Advertise here!
Strange tube pilovis Tubes / Valves 23 8th December 2012 11:05 AM
strange tube gianis33 Tubes / Valves 19 26th January 2009 12:23 AM
strange tube adalin Tubes / Valves 5 28th August 2007 09:52 PM
Tungsram tube data Diy martin Tubes / Valves 3 30th December 2004 10:59 AM
Strange Tube adalin Tubes / Valves 11 14th July 2004 07:30 AM
