Calculating cathode follower using 12AU7 for 90V supply - diyAudio
Old 11th October 2014, 06:40 AM   #1
Default Calculating cathode follower using 12AU7 for 90V supply
Hi everyone,
Need help calculating resistors for cathode follower. Here is schematics:
Power supply will be 90V.
My estimate values:
RL = 3 kOhm
RB = 200 Ohm
RG = 100 kOhm
Cin = 2uF
Cout = 2uF
Old 11th October 2014, 07:24 AM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
For close to 45V on cathode, Rb=390r and Rl=18k
Ignore the red line, I just "borrowed" this graph from another page.
Old 11th October 2014, 07:40 AM   #3
Why 45V?
Old 11th October 2014, 07:53 AM   #4
artosalo's Avatar
Originally Posted by gooduser View Post
Need help calculating resistors for cathode follower...
Essential design information missing. Maximum signal level and load impedance.
Old 11th October 2014, 08:18 AM   #5
jerluwoo's Avatar
45V is half of your 90V B+. Generally the best place to start. Blue line.
Old 11th October 2014, 08:21 AM   #6
Load impedance 980 Ohm, max input level - CD or iPod
Old 11th October 2014, 08:31 AM   #7
jerluwoo's Avatar
Hope you like distortion.
Old 11th October 2014, 08:35 AM   #8
freddi is offline freddi  United States
freddi's Avatar
ideally Rk like a plate load resistor, should equal 2Xrp at the operating point - that's an awfully low Z but not a lot of voltage to swing
Old 11th October 2014, 09:02 AM   #9
I'm assuming I should either increase voltage or load resistance? What would those be for operating without "distortion"? Thank you.
Old 11th October 2014, 09:10 AM   #10
Would increasing load resistance to 1.8k help?
chinese ebay 12au7 + 6dj8 white cathode follower preamp boards? ericj Tubes / Valves 19 3rd October 2014 06:32 AM
Aikido cathode follower (ACF) with 12au7 Gost22 Tubes / Valves 11 5th January 2014 10:19 PM
simple 12AU7 cathode follower Southside Ron Tubes / Valves 18 1st April 2007 05:02 PM
Replacing a 12AU7 in a cathode-follower. beppe61 Tubes / Valves 51 28th March 2007 09:05 AM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
