Has anyone tried a 6S4A as a 300B driver tube? - Page 2 - diyAudio
Old 25th January 2004, 11:15 AM   #11
MIKET is offline MIKET  United States
MIKET's Avatar
Send a message via Yahoo to MIKET
Default Here is the circuit after some minor tweeks
All filiments are DC.
1 minute timer for B+
Constant Current Source found at
http://home.zonnet.nl/horneman/mosfet.htm
Old 18th July 2011, 02:18 PM   #12
alexg is offline alexg  Philippines
alexg's Avatar
Hi MikeT, did you ever build this amp?
I like the 6s4a (I have an amp using 6s4a as power tube and it sounds great). I also built a 6s4a WOT preamp and I like it.
Am thinking of building a 300 SE with 5687 input tube and 6s4a as driver.
What do you think guys?
Old 18th July 2011, 09:12 PM   #13
работник
Rod Coleman's Avatar
6S4 is a good looking triode, but is designed for 150V operation, and a limit of 160V.
Meanwhile the 300B is normally biassed at -60 to -80V, and to allow some margin, the driver must be able to swing +/- 100V. With anode voltage = 150V idle, 6S4 can manage the negative swing, but going +ve, the curves become obviously nonlinear above 200V or so, even if CCS loading is used.
Only high quality option is to try a series cascode, which is what the tube was designed for. IME, an NPN transistor in the upstairs position is best here.
Old 18th July 2011, 09:24 PM   #14
SY's Avatar
Tung Sol datasheet for 6S4 says 500V max. GE datasheet for 6S4A says 550V max. The 6S4 is a terrific driver tube and can even make a pretty decent output tube. You'll be interested to see its use in the upcoming 4th edition of "Valve Amplifiers."
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 18th July 2011, 09:54 PM   #15
kevinkr's Avatar
I was hoping it was an octal, should have known better..
Linearity looks really good, and sufficient power handling for the likes of a GM70 driving it somewhat into class A2.. A 300B should be a walk in the park..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 19th July 2011, 02:42 AM   #16
alexg's Avatar
Thanks Kevin and SY, I will breadboard the 300B amp, either 6sn7 or 5687 for input, 6s4a driver, 300B output.
I need to gather parts, this will be an exciting project!
Old 19th July 2011, 04:55 PM   #17
Pano is offline Pano  United States
Pano's Avatar
A nave question:
Does the 300B really need a driver? Isn't there a nice pentode that can do duty as a voltage gain stage and have enough current, too?
Old 19th July 2011, 05:15 PM   #18
smoking-amp's Avatar
"Linearity looks really good"
Umm, did you look at the 3rd page of the datasheet? The Mu curves are horrendous. Not even constant Mu at constant current. Should work OK for P-P, but SE looks like a disaster. As suggested earlier, it looks just like a bigger version of a 6C4.
http://frank.pocnet.net/sheets/093/6/6S4A.pdf
http://frank.pocnet.net/sheets/093/6/6C4.pdf
Old 19th July 2011, 05:17 PM   #19
SY's Avatar
The test bench says otherwise.
Old 19th July 2011, 05:58 PM   #20
"The test bench says otherwise."
Well, if the 6S4A datasheet is to be believed, it might work for 2nd Harmonic driver cancellation with the 300B. Has very high 2nd harmonic like a 12AT7.
Hashimoto A-105 - 6S4A jazzbo Tubes / Valves 15 30th December 2012 11:21 AM
Low voltage 845SE with 300B driver Ziggy Tubes / Valves 6 18th February 2009 05:16 AM
Using 6L6 for 300b driver papparazzi Tubes / Valves 6 2nd July 2006 08:03 PM
6s4a as driver for 6as7 in SEAmp alejo Tubes / Valves 8 23rd December 2004 09:08 PM
JJ Tesla ECC99 as a driver for 300B-2A3 konstantin Tubes / Valves 6 1st July 2003 08:43 PM
Copyright 1999-2017 diyAudio
