Large 9pin socket needed - diyAudio
Old 21st September 2014, 09:27 PM   #1
Default Large 9pin socket needed
I have some old 9pin (similar to octal size with 9 pins) RCA mic input transformers that I love the sound of! Problem is, I can't implement them until I get a female panel mount socket for them! Anyone got any, or a referral to where I can source some?
Thanks!
Old 21st September 2014, 09:37 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Look for novar and magnoval sockets. One of these should fit.
Frank
Old 21st September 2014, 10:10 PM   #3
wrenchone's Avatar
Both the novar and magnoval sockets probably won't fit the transformers, as the transformers likely have pin sizes similar to the usual octal tube. I have a pair of transformers that have 11 pins, and I found some relay sockets to accommodate them. 9-pin sockets are made that will fit the octal pin size. You may be able to find some on E-prey. Surplus Sales of Nebraska has them, but they ain't cheap. A Google search for "9-pin octal-style socket" will shake out a few other sources.
Old 21st September 2014, 10:19 PM   #4
fdegrove's Avatar
Ah...Indeed, if the pins are the same size as the octal one then the relay sockets are what you need.
Not sure if these exist in the typical octal tube socket style though.
Frank
Old 22nd September 2014, 01:16 AM   #5
shooter is offline shooter  United States
Surplus Sales of Nebraska has them, look under medium tube sockets, pretty expensive though.
Old 22nd September 2014, 05:55 AM   #6
Wow! Those are pricey! $16 each. Thanks for all the awesome tips. I'm gonna keep looking, with Surplus Sales of Nebraska as my backup. I have some in an old RCA public address chassis. They are riveted into the chassis and I don't want to damage them during removal.
Old 22nd September 2014, 07:05 AM   #7
KatieandDad's Avatar
Can you not just use socket pins and some heatshrink tubing ?
Old 22nd September 2014, 07:26 AM   #8
wrenchone's Avatar
The cheapest on the web I've seen so far for a 9-pin octal is $15 at Pacific TV in Canada.
A tip - try emailing Anchor Electronics Anchor Electronics | Silicon Valley's Parts Store and asking nicely - they may still have some in their miscellaneous rack near the front door. You may need to throw in some other stuff to make their minimum for a mail order. Any way you go about it, it looks like you're going to have to lay down some coin....
RJ 12 socket needed ian33 Parts 0 13th November 2012 08:08 PM
Leak amp power plug and socket needed limono Swap Meet 3 21st June 2012 03:28 AM
help needed: Alpair 7 in a large room KrakBoem Full Range 6 26th July 2011 12:27 PM
8 Pin DIP Socket Help Needed KP11520 Chip Amps 15 25th August 2007 05:52 PM
Large to monitor - crossover-adaptation needed mikekiwi Multi-Way 3 8th April 2007 09:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
