6N16B Aikido Cathode Resistors - diyAudio
Old 20th September 2014, 04:06 PM   #1
Bravick is offline Bravick  South Africa
Default 6N16B Aikido Cathode Resistors
Good day all,
I need some help calculating the cathode resistor values for the 6N16 for use in the Aikido.
B+ is 200v.
I would like to run the input stage at 4ma.
Output stage at 6.2ma.
The available datasheets are not fery helpfull.
I am unable to determine rp, therefore unable to calculate with JB's forula.
Your help will be greatly appreciated.
Old 20th September 2014, 06:12 PM   #2
azazello's Avatar
You can start with 600-700-800 ohm and decrease it to receive 4 ma, counting acc. Ohm's low I=U/R cross the cathode resistor.
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 20th September 2014, 06:14 PM   #3
Thank you!
I was thinking along the same lines. I have some 620 Ohm resistors that I was thinking of starting with. Measure the voltage drop and adapt from there.
Aikido CF cathode resistor? Sodacose Tubes / Valves 14 5th January 2014 09:36 PM
Aikido Cathode Follwer Question needtubes Tubes / Valves 15 2nd January 2014 01:18 PM
Aikido Cathode Follower Bengali Tubes / Valves 18 28th August 2013 10:41 PM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 01:37 AM
Replacing cathode resistors of Aikido 1st stage (or other SRPP circuit) with chokes snoopyma Tubes / Valves 1 31st July 2006 06:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
