4P1L in parallel Single Ended
Old 19th September 2014, 03:03 AM   #1
aldovan is offline aldovan  Brazil
Talking 4P1L in parallel Single Ended
Friends
This amplifier prototype play two 4P1L in parallel single ended.
The sound is very detailed. Output transformer is a DIY 2K5 ohms.
Plate voltage is 200V and 25mA per 4P1L. Coupling capacitor is a Russian K40Y-9.
The sound is very detailed, see the video
https://www.youtube.com/watch?v=sDny...ature=youtu.be
Aldovan
Old 19th September 2014, 03:26 AM   #2
mcandmar is offline mcandmar
Your video is totally useless. Can you please show us a schematic, or the actual amp?
Old 19th September 2014, 04:04 AM   #3
This is a prototype, not a final amplifier, the prototype is ugly, have only a lot of wire and the components.
I need draw the schematic, I build of my mind.
Old 19th September 2014, 04:52 AM   #4
hooman is offline hooman  Iran
hooman's Avatar
technical people who want to know what you did need schematic .
Old 19th September 2014, 04:54 AM   #5
Default new video
Can you see this video ?
https://www.youtube.com/watch?v=b-z6ojaulzw
Old 19th September 2014, 04:56 AM   #6
Yes, this is true, I will draw the circuit...
Old 19th September 2014, 04:56 AM   #7
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
can you post your schematics? i am making one myself now....thanks..
i am targetting 250 volts plate and 60mA for two tubes in parallel,
this way it is easy to compare with a 2A3 set that i did several years back..
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 19th September 2014, 05:23 AM   #8
directdriver is offline directdriver  United States
directdriver's Avatar
Utterly useless video. What's the point of showing a video of a speaker cone when the main concern is the amp?
A schematic is much appreciated.
Old 19th September 2014, 09:43 AM   #9
LAZAROIU is offline LAZAROIU  Romania
Hello!
Maybe someone is interested SPICE tube model 4P1L pentoda.
I think you can easily design a schematic and then went into practice ...
*4P1L UG2=150V
*Vp_MAX=270.0 Ip_MAX=0.12 7 0 1MEG
SUBCKT PENT_4P1L_2 1 2 3 4 ; P G K G2
PARAMS: CCG=3P CGP=1.4P CCP=1.9P RGI=2000
+ MU=11.808 EX=1.4 KG1=1210.0 KG2=4500.0 KP=43.2 KVB=32.4
DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1 7 0 VALUE= ;
E1 BREAKS UP LONG EQUATION FOR G1.
+{V(4,3)/KP*LOG(1+EXP((1/MU+V(2,3)/V(4,3))*KP))}
G1
1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,3)/KVB)}
G2
4 3 VALUE={(EXP(EX*(LOG((V(4,3)/MU)+V(2,3)))))/KG2}
RCP
1 3 1G ; FOR CONVERGENCE
C1
2 3 {CCG} ; CATHODE-GRID 1
C2
1 2 {CPG1} ; GRID 1-PLATE
C3
1 3 {CCP} ; CATHODE-PLATE
R1
2 5 {RGI} ; FOR GRID CURRENT
D3
5 3 DX ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
Old 19th September 2014, 10:15 AM   #10
I propose a theoretical project 2x4P1L performance parallel configuration is attached
4P1L in parallel Single EndedHide this!Advertise here!
Parallel Single-Ended Questions Sherman Tubes / Valves 13 6th October 2017 08:09 AM
parallel single-ended 12W6 scott17 Tubes / Valves 17 8th September 2017 04:20 PM
Mission 300b parallel single ended duderduderini Tubes / Valves 1 17th October 2007 10:21 AM
Parallel single ended or push-pull? Jeffy74 Tubes / Valves 6 12th February 2004 07:04 AM
Parallel, single-ended Pentode. How? arnoldc Tubes / Valves 2 16th December 2003 11:35 PM
Copyright ©1999-2017 diyAudio
