separate filament transformer for 5u4g? - diyAudio
Old 16th September 2014, 12:38 PM   #1
donovas is offline donovas  South Korea
Default separate filament transformer for 5u4g?
hello.
i use 5u4g for preamp. but hard to get right transformer in korea. so i use
2x 220v secondary transformer for 220-0-220. 1x 5v transformer for filament. this ok? or burn the house?
Old 16th September 2014, 12:51 PM   #2
oldschooltube's Avatar
If it is for a preamp and depending on what tubes you use why dont you consider using a 6BY5GA television damper diode for a rectifier?
6BY5GA will deliver 175 mA and the heaters only use 1.6A current @ 6.3V with less voltage drop than a 5U4.
They are also cheap!
Marty: "Why don't you just make 10 louder?"
Nigel: "...These go to 11."
Old 16th September 2014, 01:29 PM   #3
KatieandDad's Avatar
Absolutely no problem using a separate transformer for the heaters.
As rectifiers regularly use directly coupled cathodes you are actually doing yourself a favour by reducing the interwinding voltage in a single transformer.
Old 16th September 2014, 02:26 PM   #4
I find that using one of those 6.3v small filament XMFs & knock down the primary side with a power resistor of 5 to 12 ohms works great for use w/a 5v rectifier.
Old 16th September 2014, 04:39 PM   #5
thank you. 6by5ga good choice. but i have 5u4g already
so for plate, two 220-0, 200-0 wired for 220-0(220 and 0)-220 no problem?
Separate Filament and B+ Switches Magz Tubes / Valves 51 5th October 2012 07:45 PM
Power Transformer - Can you use separate tap for screens? JWK Tubes / Valves 19 17th December 2010 01:12 PM
Fitting separate transformer into CD52 enzedone Digital Source 0 27th August 2009 01:56 PM
How to separate E from I in transformer? mad_z Parts 15 1st November 2006 09:20 PM
Copyright 1999-2017 diyAudio
