UXCV-11 plates? - diyAudio
Old 15th September 2014, 08:40 AM   #1
Default UXCV-11 plates?
Hi everyone, I recently lost a transformer on my device that was outputting an unknown voltage and amperage to a pair of UXCV-11 bulbs, as well as additional wires to the "plate caps" of the "unit". I believe by "unit" I am referring to the UXCV-11 bulb's "plate caps", but I don't know exactly what I am referring to by "plate caps" here. The pair of UXCV's are the only bulbs in the machine aside from one other small one, and according to my source the "transformer sends one pair of wires to power up the UXCV bulbs, and another set of wires to power the plate caps, which do all of the work". I recently was able to get the transformer replaced by a very helpful person, but unfortunately he had to leave and return home 2000 miles away. While the bulbs are receiving the power to light up at 2.5 amps and 10 volts, the plate caps are just not getting enough power. Sadly, the original transformer is unmarked and has no references to its power outputs or what its doing with the output electricity. We replaced it with this: AS-8T650 - AnTek Products Corp , which does work, sort of, but the secondary wires need to output just a little more power. By a little more I'm not quite sure how much! If the plate caps are part of the UXCV-11's, does anyone know what their operational range is?
Old 15th September 2014, 09:33 AM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
http://www.tubecollectors.org/united...ves/uxcv11.pdf
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 15th September 2014, 03:27 PM   #3
Wow I feel stupid haha. Thank you. Can I ask, I see the tube has 3 valid pins or electrodes rather for connection. On the bulb insert bracket it says "P P G", which I think is Filament +, Filament -, and Grid. Is the Grid suppose to mean "Plate"? How do I get power to the "plate" part of the bulb? It looks like the grid ratings are separate from both filament and plate. Also, if anyone can maybe help me on this... By doubling the output wires on the AT650 replacement transformer, I've got power to the filaments at 2.5 amps and 10 volts by using a pair of 25 watt 1 ohm resisters. However, I'm looking at the secondary wires that do all of the work. By doubling those, I think I go from 650V .62A to 1300V .124A. Reading the UXCV11 specs here, it looks like the bulbs maximum plate ratings are 1250V modulated / 1500V unmodulated, and 125ma modulated / 150ma unmodulated. Doesn't 1300V at .124A mean 1300V at 124ma? Aren't the bulb limits for the plate cap already being pushed near the top? Do I have this incorrect somehow?
Old 15th September 2014, 03:38 PM   #4
Yes, the UX is the mother of all valves! The Plate is the Anode. The Cathode is the filament and the Grid is the Control Grid.
Hope that helps.
11.11 E-shopping festival big discount!! siliconray Siliconray Online Electronics Store 1 10th November 2013 04:35 PM
WTB: Jensen JT-11-BMCF or JT-11-DMCF or Lundahl LL1690 Groundloops Swap Meet 1 1st February 2012 08:37 AM
CD80 clock frequency 11.2896 to 11.0592? Sam Spade Digital Source 5 24th October 2010 03:44 PM
free 11 by 11 inch heatzinc good for class a karma Swap Meet 9 14th January 2007 02:30 AM
WTB 11" X 11" r-thetas from old GB... sklimek Swap Meet 0 27th April 2005 03:22 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
