| diyAudio Sponsor | ||
Well I picked up an ancient Sony reel to reel recorder for $5 from a junk store. It was a pretty solidly made stereo beasty, but in pretty bad exterior condition.
Anyway I opened it up, turns out it has a pretty sweet amp in it, 6AQ5 in SEP in their own amp chassis, which can be totally removed as a self contained unit (with cool retro mesh!) The power transformer is beefy too, and nicely potted (black box in the top right of the photo.) Also in it was a telefunken ECC83... made by Mullard!? Weird... Anyway it seems that the output trannies might be fubared, one the primary resistance measures 450 ohm, the other 1300 ohm. Not shorted to ground though. Any ideas? Should two identical transformers vary this much? Cheers Henry |
#2 |
The primary resistances of the two transformers should be a closer match. Did you remove the 6AQ5 tubes before measuring?
Do the trannies have a screen tap?
Frank |
#3 |
diyAudio Moderator Emeritus
Measuring inductors with an autoranging meter can give misleading results.
If you use this kind of meter, I suggest repeating the test with the secondaries loaded or shorted. |
#4 |
Noticed A black spot on one of the transformers ,is that the one that reads low .
To be better one must be different ,but to be different is not necessarily better . |
| Fried T-Amp? | Bingobing | Class D | 11 | 2nd November 2010 03:12 AM |
| Fried t-amp? | kaban | Class D | 24 | 23rd June 2006 10:03 AM |
| Fried New Amp | memito | Car Audio | 8 | 10th August 2004 02:38 AM |
| I think I fried an amp | mashaffer | Car Audio | 1 | 20th July 2004 01:54 AM |
| Page generated in 0.07148 seconds (70.58% PHP - 29.42% MySQL) with 11 queries |
