High Voltage Derived Bias Supply
Hey Anyone,
I need a negative bias supply and unfortunately the power transformer doesn't have a bias tap. I tried using a separate transformer but it is a source of noise.
If I want to use the HT supply I understand how to set up the resistors to get the necessary voltage/adjustment. The question is what type of rectifier should I use?
Right now the HT from the main transformer is attached to a GZ34 rectifier tube. It seems I have two options? I could connect to one side to the HT and use a half wave. Or attach to both and use a full wave. It will be a SS rectifer so the bias comes on before the HT.
Someone sent me a basic schematic to do this but I've lost it. If I remeber correctly it had one reversed diode in series and one to ground.
Thanks, Kevin
from the web....
http://education.lenardaudio.com/en/14_valve_amps_6.html
Yes, the circuit shown by mr2racer is wrong, The 470k resistor should be connected to the opposite side, to the 100 k resistor. And 100 uF caps to bias are way to big, as kevin pointed at. Better to use one of the earlier circuits, and 20k pots with about 1 uF of decoupling :)
As Seppoa said above: NEVER regulate the bias supply in a fixed bias mode amp, unless B+ is regulated too.
And also, you should check the bias supply RC time constant which must be shorter than the main B+ supply rise, or you might under-biasing the output tubes during start-up. (don't use a too big bias filter cap if your bias supply is derived from the H.V winding through a high value resistor and your main B+ rectification is solid state)
AJT, yes unregulated supplies are OK, the issue is that the plate supply and the grid bias should track, ie if B+ grows, the G1 bias have to get bigger, in the negative voltage. So need the G2 supply track the variations, in symmetry to B+...
Well, the heater supply are not so important, but also variations here influence the current thru tubes,,,
