Cap substitution help - diyAudio
Old 15th August 2014, 02:27 AM   #1
arficus is offline arficus  United States
Default Cap substitution help
Please find relevant schematic section attached (from Luxman CL34 preamp). There are two 1uf coupling caps in parallel coming off of V7. Is there any reason (electrical, sonic, whatever) one shouldn't substitute one 2uf in their place?
Thanks.
Old 15th August 2014, 02:30 AM   #2
Einric is offline Einric  United States
Einric's Avatar
Half the ESR, double the ripple, symmetrical layout??????
Maybe the builder didn't have 2uF caps in his parts bin but he had plenty of 1's?
Old 15th August 2014, 03:15 AM   #3
rayma is offline rayma  United States
Thanks.
Possibly, the cap mfr chosen may not have made a value in that series over 1uF.
Old 15th August 2014, 03:50 AM   #4
Bob Richards's Avatar
Maybe two 1uF caps fit better than one 2 uF cap physically. A more typical reason is that 1uF caps are used elsewhere in the system, and part quantity discounts could be had. There shouldn't be any significance difference electrically.
Old 15th August 2014, 04:00 AM   #5
AJT is offline AJT  Philippines
AJT's Avatar
dc blockers, those caps go to a selector switch, some sort of tone control network...file:///C:/Users/TECSON/Desktop/hfe_luxman_cl-34_schematic.pdf
no problem with using a 2ufd single cap in plaxe of 2 x 1ufd...
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
GZ37 Substitution? Hackensack Tubes / Valves 7 25th April 2014 09:37 PM
2SK3057 Substitution 91h22a Car Audio 2 25th May 2011 04:29 PM
Transistor Substitution hewlew1 Solid State 82 4th September 2007 02:49 AM
E182CC substitution ? bembel Tubes / Valves 5 11th November 2006 04:11 PM
substitution for 7355 sweet Tubes / Valves 3 30th December 2005 10:49 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
