#51 |
Erik,
I know there are a number of companies producing very high quality HiFi products in your area of the world. Please check out google.com and go to rec.audiotubes and try and contact a tube stereo Do It Yourself lover in your area. Most people that are very happy to share knowledge and possibly parts to get a new person started in this fun hobby. I have been blessed with this myself and have learned so much and been exposed to even more. Most of the guys out there listening to great sound for a small price were taught about it by some one else, and are happy to pass it on. This is a great place to get info but if you can find a mentor that will give you a bit of time when you need it. You would be surprised at how many tube audio guys are out there.
Thatch |
#52 |
#53 |
Erik,
Have you made a final decision. If you have not yet made one, then, perhaps this forum should be able to help you design your own amplifier. There is a lot of knowledge among the members of this forum. It is about time that we pooled our resources and have a common project. A simple topology for you to consider would be the Ralph Amplifier. Look at the threads in this forum. The input stage including the driver transformer should only need minor changes. You could consider a higher dissipation tube for the output stage. I am thinking of the Russian triode 6C41C. This is a 25-30W tube and requires low anode voltage. More info at: http://www.mclink.it/com/audiomatica/tubes/6c41.htm You could also consider a solid state bridge rectifier for the power supply. I know that this project may exceed your budget. But you are going to order components as you need them. What do you think? Mohan |
#54 |
#55 |
Erik,
This is good news. Mohan |
#56 |
Have you seen how much differebt tube amp kits available?
Check out the directory for KITS: http://www.worldtubeaudio.com/ |
| thinking about building my first cabinet | spc18 | Full Range | 1 | 10th July 2007 01:44 AM |
| Thinking about building an OB using ironwood (ipe) | owdi | Multi-Way | 31 | 18th January 2007 03:46 AM |
| NOOB! Thinking of building a 4 ch 3875 amp - questions.. | quickshift | Chip Amps | 7 | 7th August 2005 01:57 PM |
| Thinking About Building A Class A Amp, But Have Some Questions | li_gangyi | Pass Labs | 13 | 16th January 2004 05:28 AM |
