Tube newbie, anyone familar with s-5 k-502? Help needed please - diyAudio
Old 14th August 2014, 01:46 AM   #1
Default Tube newbie, anyone familar with s-5 k-502? Help needed please
Hello,
First off I would like to say hello to everyone here, I have lurked around the site a bit and decided this looks like the place for me. I have been into audio equipment for quite sometime and consider myself experienced (a little at least) in trouble shooting, repair, and restoration of solid state equipment. After reading the many reviews and posts on the s-5 tube kits I decided to order the K-502. Being the "hobbyist" that I am I couldn't just build the kit as intended and decided to do some mods. I built a chassis, upgraded coupling caps, installed snubbers across filaments and HV, removed input dc blocking caps from signal path, used a uf4007 from bridge rectifier to filter cap, upgraded binding posts and rca jacks and upgraded volume pot. After finishing the project I get absolutely no output . The tubes glow fine and there is no sign of the obvious such as bad soldier joints, reversed polarity on components ect.. Nothing is shorting out or too hot. I know there is several threads on this amp and I have spent hrs researching and thought it would be best to post here and ask the experts for help. I came across the on thread recently where a member was having a similar problem with a K-12 kit and it ended up being a grounding issue with the binding posts, I don't think that is the issue here though. Also I see the Voltsecond mods mentioned on almost all the threads, his webpage seems to be out of commission does anyone know where I could access this info? All info and help would be greatly appreciated. BTW I haven't took any measurement's yet and hope to get a chance to work on it a little more tonight.
Thanks,
Jason
Old 14th August 2014, 03:16 PM   #2
Soonerorlater's Avatar
Hi jhow5757, welcome to the forum.
Nice build
A few years back I built a K502 and did all your mods plus changed the output transformers to Hammond 1609s.
Using a valve amp without speakers attached could damage your output transformers, so a quick check there might be prudent.
As you have no sound from either channel the fault is likely to be in a part of the circuit that is common to both channels. I would first check that you're getting a B+ exiting that UF4007 mod. IIRC it should be around 210 Vdc
On the signal input side make sure you that you have extended the volume pot out of the pcb correctly.
When white moths were on the wing,
And moth-like stars were flickering out,
Old 15th August 2014, 01:35 PM   #3
Thanks for the info, I would think the opts should be fine as they are brand new and never ran without a load. I will check the B+ voltage exiting uf4007 and report back as soon as I get a chance. Hopefully I will find time to get back at it this weekend.
Thanks again,
Jason
Anyone familar with the Audio Nirvana 15" FR or coax? Rick J. B. Full Range 7 10th April 2012 05:36 PM
Newbie- Tube Testing RF Amp tube jsternmd Tubes / Valves 0 25th October 2011 05:44 PM
NAD 502 with newbie attached planarboy Digital Source 6 2nd August 2010 03:28 PM
Some general tube questions from a Tube newbie !! Minion Tubes / Valves 11 6th March 2010 01:38 AM
Anyone familar with this Technics driver of at Apex Jr? Hybrid fourdoor Multi-Way 4 23rd June 2003 02:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
