Pentode C.F, where to connect the suppressor grid ? - diyAudio
Old 11th August 2014, 02:46 PM   #1
Tubologic's Avatar
Default Pentode C.F, where to connect the suppressor grid ?
I intend to use a triode-connected small power pentode (E80L) as a cathode follower for driving a 211 PP triode output stage. The E80L is a true pentode and has a separate suppressor grid (G3) connection which is usually connected to the cathode in most circuits. Now I'm wondering if it would be better to connect the suppressor grid to the cathode or the anode when used in a cathode follower configuration, and why ? (the screen grid G2 being tied to the anode for triode operation).
Old 11th August 2014, 02:52 PM   #2
DF96 is offline DF96  England
If g2 is wired to the anode then g3 is no longer needed, as primary electrons and secondary electrons end up in the same place. It doesn't matter too much whether you connect it to the anode or cathode.
Old 11th August 2014, 06:26 PM   #3
disco is offline disco  Netherlands
disco's Avatar
Might the small interelectrode capacitance be of importance?
jaap
Old 11th August 2014, 08:12 PM   #4
In audio, for a CF? No.
Old 14th August 2014, 08:29 AM   #5
RE 604 is offline RE 604  Germany
RE 604's Avatar
.........the data sheet says "g2 on a and g3 on k" for triode operation .
Valvo Handbuch Spezialröhren 1966
Kind Regards ,
Alexander .
No reason to get excited : Jimi Hendrix .
Pentode pre/compressor (warning nube attempt at circuit drafting) --suppressor grid Blue Jinn Tubes / Valves 33 18th August 2014 08:25 PM
grid stopper and grid choke on pentode input YouAgain Tubes / Valves 3 12th February 2012 09:32 PM
Beam pentodes and suppressor-grid pentodes of same type jon_010101 Tubes / Valves 3 2nd May 2009 11:18 PM
Pentode current sink - how to connect the control grid? ray_moth Tubes / Valves 4 20th December 2004 02:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
