I'm repairing a broken screen supply, and it would be easiest to test this w/ everything in place, but w/ the screens temporarily disconnected. Is it safe to power up a pentode w the screen disconnected for a few minutes? I can't think of any reason it would be a bad idea, but it doesn't hurt to ask the experts...
Thanks's DF, I was thinking about that.... but, didn't take any precautions this time. I will next time.
Usually I'd just pull the tubes, but in this amp they're under cages.
I was fixing a maida regulated screen supply. I replaced the lm317 due to the symptoms. That didn't work, so I replaced the transistor. I was confused for a while when that didn't help, but it ended up being the 12v zener that failed!
- Tubes / Valves
- Is it safe to run pentode w/ no screen voltage for a min?
