Thank you for your reply. I used this M2, but I want to know the exact volt of TX position , after opt connected this (Tx) position, another wire of opt connected to B+(260v) in M2.
"But the M3 or L3 is feeding a 260 DCV to the output transformer's HT point, after the winding resistance, at least 230 DCV or above."
http://www.diyaudio.com/forums/tube...n-audio-note-m10-schematic-japan-version.html
Great. Up to now, my kit is 255 DCV, the winding resistance is about 565ohm. Is it right? I feel high gain, Can you show me how to reduce gain at this situation.
Thanks a lot
High gain?
Audio Note L3 Line Pre-Amplifier Kit
"Specifications
Input Impedance 100K
Input Sensitivity 126mV
Gain x8 (single ended mode), x16 (balance mode)
Valve Complement 2x 5687 (line stage) 1x 6X5, 1x ECL82(PSU)
Chassis dimensions 38.1cm(15") wide, 40.64cm(16") back to front, 14.6cm(5.75") height including height from floor"
I believe, your transformer is not 33:1 step-down version.
Audio Note pre-amplifier output transformers
"Specifications
the ANK OPT (which are no longer the AN made ions) may not be the 33:1 step down, something like 28:1.
This pre gives only 8-10 times voltage gain only depending on the tube combo used (5687, 7044, e182cc, 6463, ecc82, 12bh7, 6sn7, ecc99...), not excessively high.
you may want to address the gain of your system in the source or power amp ie: AN DAC to L3 pre to classic 6sn7-6sn7-300b is definitely too much gain.
Your idea is so great. And now, My kit used volume not over 3h, sound is extremely loud. If I increase the wiring resistance of primary, and decrease the wiring resistance of secondary .I feel weak sound, lacking of dynamic and detailed sound.With "something like 28:1". I tried to do it , the result is medium gai, but sound not so great...
- Tubes / Valves
- Output Transformer for L3 pre Audio Note
