845 set bias. - diyAudio
Old 3rd August 2014, 01:10 PM   #1
Default 845 set bias.
Hello , this is my beginner question i have this integrated amp supose to be ongaku clone with 2×845 rca tube , 2×12sn7gt , 2×ecc83 and four rectifier tubes the amp was fully restored replaced all caps with solen , mundorf , auricap , after testing everithing is ok but it seems to me that the right 845 tube is a litter brighter than left i have a picture of a module to setup bias can any one explain to me how should i setup bias where to point the probes from voltmeter i must say i dont have any specs from amp or tubes.
I know there is a high voltage and im aware of danger.
Im posting a picture of bias plate.This pictures are from prevoius not restored amp.
THX for any help
regards
Old 3rd August 2014, 05:56 PM   #2
Aleks1 is offline Aleks1  United Kingdom
How long is a piece of string?
Twice as long as half it's length.
Measure some things like plate voltage etc if you can, and get back to us.
Have fun.
Old 3rd August 2014, 06:55 PM   #3
Originally Posted by mcnaget View Post
...it seems to me that the right 845 tube is a litter brighter than left ...
What do you mean? Brighter sound or brighter light from the fillament?
The intensity of the light is not affected by the bias.
Old 3rd August 2014, 07:52 PM   #4
Default 845
I mean brighter light . Im not sure but as im informed those tubes are 5-6 years old so are the rectifiers and 12sn7gt the 12ax7 ei niš was recent replacement.
thx
regards
Old 4th August 2014, 03:47 PM   #5
jervill is offline jervill  United Kingdom
If it's the brightness of the filaments then maybe check the filament voltages. If one is way over or way under, it may explain the difference in brightness. As mentioned above, the bias shouldn't affect this.
If it is an Ongaku clone then there are examples of the schematics on the net. I would examine those and see if it tallies to what you have wired up in the amp. Regardless, it would be a good idea to give a good look at the amp and trace a schematic for it. Should help you work out where to probe and what readings to expect roughly, especially if your planning to examine it deeper. Good luck!
Old 4th August 2014, 04:28 PM   #6
работник
Rod Coleman's Avatar
Definitely - you need to check the voltage across each filament. It should be 10V (9.5V to 10.5V). Outside of that range (esp. >10.5V), the lifetime of the tube is dramatically reduced.
Old 5th August 2014, 08:45 PM   #7
Default 845
Thanks for advices and help , posting the picture after restoring i replace 12ax7 with sovtek lps there is a slight birghtness on 845 tube but the voltage is ok im leaving now amp for new parts to settle down .
regards
Old 5th August 2014, 10:12 PM   #8
HollowState's Avatar
That's a nice project but I see one thing that needs attention. There are several places where wires are going through holes in the chassis. There are no rubber or plastic grommets. I know at this point it's a big job to add them, but it needs to be done. Especially with the voltages involved with tubes. You are taking a big risk because some of the through holes are pretty tightly packed with wires. They need to be enlarged and a protective grommet installed. And if the wire is Teflon™ it's all the more important because Teflon will cold form. That's what caused our space shuttle to burn up on the launch pad years ago killing all three astronauts.
"It is hard to imagine a more stupid or more dangerous way of making decisions than by putting those decisions in the hands of people who pay no price for being wrong." ~Thomas Sowell
Mr. Lian 845 SET – more kit rather than commercial product. avp1 Tubes / Valves 3 27th April 2014 11:03 PM
music angel 845 SET PeterParsons Tubes / Valves 8 11th November 2013 03:12 AM
845 with kathode bias Dogie_Hogan Tubes / Valves 3 28th June 2011 09:20 AM
Help me to work on the damping factor of my 845 SET rdk845 Tubes / Valves 17 18th May 2009 02:04 PM
Tubes for Viva Solista 845 SET amp angeloitacare Tubes / Valves 9 19th September 2008 03:22 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
