diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Not connecting grids/anode can hurt tube? (http://www.diyaudio.com/forums/tubes-valves/26000-not-connecting-grids-anode-can-hurt-tube.html)
Redemption 13th January 2004 08:25 PM
Hello folks,
I have a pentode/triode combination tube which runs on low voltages (12V anode). I am only using the triode for now. I didn't connect the grids and anode of the pentode, but since the triode and pentode share the kathode, electroncs are moving in the direction of those pentode grids...
Can this hurt the tube?
Greetings,
-- Charl
dhaen 13th January 2004 09:00 PM
Common cathode..
I don't see how any damage could be caused.
However, with the pentode's anode and grids floating, it could have a random effect on the triode's operation, so best to ground them.
Redemption 13th January 2004 09:03 PM
Okay, thanks!
-- Charl
fscarpa58 14th January 2004 08:16 AM
are you sure of this? strange!
bye
Federico
dhaen 14th January 2004 10:13 AM
shared cathode
Originally posted by fscarpa58
[B]
/B]
There have been a few valves like this.
The only B9A valve I know of is the ECL80.
Among 7 and 8 pin valves, Eg B7G, Octal it is necessary to share because there are not enough pins.
fscarpa58 14th January 2004 10:33 AM
I learned something new today
thank you
Federico
Redemption 14th January 2004 11:20 AM
Tube I'm using is the ECH83.
-- Charl
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
