power output of EL34
Old 28th July 2014, 06:02 AM   #1
hschaser is offline hschaser  Singapore
hschaser's Avatar
Default power output of EL34
Hi All,
I am intending to get a kit el34 intergrated amplifier for diy.
With 6SL7 as the pre section.
Need to know how can i have better/greater power output than 13w per channel max as spec.? As i see from spec sheet EL34 can output greater power than 13w. Have it got to do with the power transformers and outputtransformer?
Old 28th July 2014, 06:55 AM   #2
Tesla88 is offline Tesla88  Italy
Tesla88's Avatar
Any link to the kit you watching?
As long as we don't know circuit topology and class of operation , it's impossible to say...
Are we talking about 1 EL34 or pair ? With only one EL34 per channel you have a SE class A amp with 8W typ. sine power .
With a pair of EL34 you can get more power in push pull , but again , output power vary with plate voltage , primary impedance of Output transformer , Class of operation A - Ab1 - Ab2 and output stage connection Pentode - UL - Triode.
For ex. a push pull , triode connected , class A would give about 15W . . .
Old 28th July 2014, 07:11 AM   #3
jazbo8 is offline jazbo8
jazbo8's Avatar
Since the max Pda for the EL34 is only 25W, the 13W output figure (which seems to suggest that it is SE) already exceeds the maximum possible Class A efficiency of 50%, in a real circuit, that figure is going to be lower, so in other words, the 13W rating is already an exaggeration - you may want to ask the seller, what is the distortion at 13W or how long is the expected tube life?!
Old 28th July 2014, 07:15 AM   #4
freddi is offline freddi  United States
freddi's Avatar
http://frank.pocnet.net/sheets/129/e/EL34.pdf
Old 28th July 2014, 07:42 AM   #5
hschaser's Avatar
Yes the configuration is for a SE amplification with a distortion level of less than 1% as stated by the seller. K will try to get korre details and post it uphere. Thanks for the help.
Old 28th July 2014, 09:08 AM   #6
hschaser's Avatar
Hi, attached are the kit details and schematics
Features and spec:
Simple electronic circuit,Ultra linear amplification circuit
Automatic bias
Using 5H choking coil to filtering
5Z3P tube rectifier
6N9P preamplifier
EL34-B power amplifier
Max Output Power 13W X 2
Load: 4Ohm or 8Ohm
Harmonic distortion: =<1%
SNR: >= 89dB
Input sensitivity: 600mV - 1V
Input impedance: 100KΩ (stereo input)
Frequency response: 20Hz - 26KHz
THD: =<0.5% (1KHz)
Silkscreen stainless steel
Recommend minimum configuration:
Bass woofer size : 6.5'' inch
Sensitivity: >= 90db (very important )
Old 28th July 2014, 09:34 AM   #7
Malcolm Irving is offline Malcolm Irving  United Kingdom
Malcolm Irving's Avatar
To avoid confusion, it isn't really an ultra-linear circuit. The person who wrote the spec. probably just meant 'very linear circuit'.
Old 28th July 2014, 09:45 AM   #8
hschaser's Avatar
Any help will be much appreciated.
Old 28th July 2014, 09:46 AM   #9
hschaser's Avatar
Thanks Malcolm for your clarification
Old 28th July 2014, 09:53 AM   #10
jazbo8's Avatar
As mentioned, the schematic does not show an UL connection, and using the figures provided above, the output power is a lot less than the 13W spec'd... 15/300 = 0.05, Po = 0.05^2*3500 = 8.75W even asssuming zero winding loss in the output transformer.
power output of EL34Hide this!Advertise here!
el34 output transformer, 3 or 5 wire ~? nigelwright7557 Instruments and Amps 18 25th June 2013 06:05 PM
EL34 pentode output in SSE Skorpio Tubelab 12 4th November 2011 10:42 AM
EL34 PP output tranny questions Ian444 Tubes / Valves 15 12th October 2010 08:46 AM
Output transformer for PP EL34 source pof@ Tubes / Valves 7 22nd May 2010 09:09 AM
