DC coupled SE SChade amp - diyAudio
Old Yesterday, 02:53 PM   #1
316a is offline 316a  England
316a's Avatar
Default DC coupled SE SChade amp
I have read quite a bit about Schade feedback on here but have hardly scratched the surface with pentodes . Was thinking about building a simple DC coupled SE amp but with an EF95 input stage as I belive these can work at low voltages . Output stage will be a 6P15P , EL822 or similar ~12 watt pentode . I'm yet to work out component values , I have built a similar (all triode) amp which worked very well but need some opinions as wether this one is a go-er
cheers
316a
Old Yesterday, 05:47 PM   #2
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Hi 316a,
Seems a good starting point to me. I've been playing with a 4P1L with Schade feedback but using a FET/BJT driver instead as per Michael Koster's version.
As the FB will be determined by the un-bypassed cathode resistor and the pentode anode resistance in combination with the Rf, you will have to estimate ra and use a pot as Rf to set the right level of FB. You can do this and monitor the harmonic profile to avoid ending up with a pentode sound rather than a more triode-like one which I guess you would prefer.
cheers
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old Yesterday, 06:19 PM   #3
316a's Avatar
Thanks ! The cathode resistor of the driver pentode will be passing the current of the output stage through it . It tends to help self-stabilise the amp (if it works like it does in my 6S45/2A3 amp) and will be much lower in value than usual , hence should not require bypassing . A bit like filament bias I have placed the driver G2 supply in the cathode of the output valve as well as the driver's cathode resistor . I'm not entirely sure how well it will work and hoping that it will all fit into place without dropping too many volts in the cathode circuit
316a
Schade SE 6550 mr2racer Tubes / Valves 94 28th January 2014 12:32 PM
Zen with DC Schade driver revintage Pass Labs 9 27th July 2011 10:34 PM
D-amp for DC coupled applications lalalala Class D 8 20th December 2010 09:23 PM
DC hybrid folded-cascode for Schade revintage Tubes / Valves 18 13th February 2010 08:09 AM
A DC coupled headphones amp Gluca Tubes / Valves 0 27th January 2010 01:08 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
