Failed Converting UL to Pentode!? - diyAudio
Old 24th July 2014, 10:32 AM   #1
Zekk is offline Zekk  Singapore
Default Failed Converting UL to Pentode!?
Hi Guys!
Kindly advice how I can simply failed for such straight forward mod?
Converted my PP Ultralinear 6550 to pentode mode by firstly disconnecting UL tap of OPT to pin #4 of 6550.
From B+, soldered a 220K to a series of 5x IN5369B, bypass with 47uf@450v , and then branch out to the two EL34.
Bias voltage was reduced to -44vdc prior to inserting EL34.
It's DEAD! Every point measures right except pin #8 of EL34. No reading at all despite pin #5 reads -44v before the 1K grid stopper.
What should I do with the CT of the OPT? Just tap it off?
Before all this, it was sounding good. Since I've a quad of Amperex brown base 6CA7, I've decided to do a switch.
As someone said: "....6550 sounds industrial, EL34 sounds sweet!" Can't get this off my mind yo.
As usual, sorry for the rambling and thanks for the help forecoming.
Zekk
Old 24th July 2014, 10:57 AM   #2
DF96 is offline DF96  England
A circuit diagram might help.
I am unclear what the 220k resistor is for. It is clearly far too large a value to provide a g2 supply for an output pentode. As I don't carry EL34 pinouts around in my head it would help if you tell us which electrode you are checking rather than just the pin number.
The CT of the OPT should be left as it was.
Old 24th July 2014, 11:56 AM   #3
Send a message via Skype™ to JonSnell Electronic
On each output socket, remove the UL tap from pin4 and connect pin 4 to HT (centre tap of output transformer) with a 1K 5W ww resistor. Connect pin 1 and pin 8 to ground.
Forget about the diodes and 220k resitor.
This will work with either EL34 or 6L6 (6550) type valves.
www.flyingmole.co.uk For World Wide support for Flying Mole, Class D, Refurbishment and Repairs. www.jonsnell.co.uk
Old 24th July 2014, 12:01 PM   #4
Depending upon the HT, the neg bias may be reduced to as little as -32.
Old 24th July 2014, 12:03 PM   #5
Originally Posted by Zekk View Post
Hi Guys!
Zekk
A 6550 is a pentode! http://www.dougstubes.com/6550-tungsol.pdf
Old 24th July 2014, 09:20 PM   #6
lechuck is offline lechuck  Netherlands
Hi Guys!
Zekk
What exactly did you do with pin 4 after you disconnected its connection to the UL tap of the output transformer?
In case you did not reconnect pin 4 to either B+ or pin 3 then your EL34's will be cut off and do not conduct current. If this is the case please connect pin 4 with a suitable (I use 3 Watt rated resistors here) 1k ohm resistor to either B+ (Pentode-mode) or pin 3 (Triode mode). Repeat this for all output valves and try again
Old 25th July 2014, 03:46 AM   #7
Guys.. no luck so far.
Configuration to run EL34 in pentode mode is as followed: Pin#4 or g2 voltage is 255vdc @ 8mA.
B+ is 505vdc. So, to achieve a constant 255vdc at g2, I calculate voltage drops divide by current, and that'll give me the value of dropping resistor.
Eq: 505v-255v = 250v / .016 = 15K6.
So, 505vdc B+ > 15K6 > 47uf@450v > g2 both EL34.
All points measures ok except pins #1/#8 have no reading at all!?
I can reverse back to my comfort zone and have my music. But then, I won't be any wiser!
Got my inspiration from the Grommes 260A.
Thanks.
Old 25th July 2014, 06:24 AM   #8
jazbo8's Avatar
Thanks.
Pin 1 & 8 are at ground potential (make sure pin 1 is indeed connected to the cathode/ground and not left floating), so should have no reading, what is the bias voltage set at?
Old 25th July 2014, 06:34 AM   #9
directdriver's Avatar
Your circuit looks like this?
Old 25th July 2014, 10:10 PM   #10
jazbo8... Pin 1 & pin8 are connected together to a 10 ohms resistor to ground. At UL mode, it measures 0.75v and that equals 75mA.
directdriver... only followed the regulated B+ to g2 of EL34. Instead of 6L6, I use zeners.
Thanks!
CCS assisted small signal UL pentode Bill*B Tubes / Valves 31 3rd October 2013 12:37 AM
Adequate switch for UL-triode-pentode mskl99 Tubes / Valves 7 18th February 2013 03:50 AM
SSE pentode/triode/UL neomat Tubelab 7 22nd July 2012 02:58 PM
converting UL in triode overdrajv Tubes / Valves 11 25th December 2007 05:21 AM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 12:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
