Valve cruelty ... - diyAudio
Old Yesterday, 07:57 AM   #1
fas42 is offline fas42  Australia
fas42's Avatar
Default Valve cruelty ...
What's audio if you can't have a bit of fun ... and learn something as well?
An interesting 'experiment' I came across ... http://home.comcast.net/~jafix/torture.html ...
Frank . . . when did you last tangle with a pounce of cats?
Old Yesterday, 09:12 AM   #2
Send a message via Skype™ to JonSnell Electronic
Try that with an 813, it has a carbon anode and I accidentaly imploded the glass when my Class C single ended transmitting output stage went to class A by mistake and continued to transmit for half an hour. With 900Volts on the anode at almost 500mA supply current. All got very hot and I dread to think of the stray harmonics knocking out TV and Radio for a few hundred yards all around. It eventually died when the air got in there are killed the heaters arcing over and taking the HT fuses.
www.flyingmole.co.uk For World Wide support for Flying Mole, Class D, Refurbishment and Repairs. www.jonsnell.co.uk
Old Yesterday, 09:45 PM   #3
tubelab.com's Avatar
I find this kind of behavior, uh...completely normal, in fact somewhat lame....You haven't tortured a tube until you have melted a few. /
Can you melt a hole through the plate of a tube, have it emit a blue ray of death, and then pop it into a tube tester to find it still alive? Yes, and the voltage drop at rated current was still in spec too. So what to you do? Turn it up some more!!!
A gassy 6V6GT becoming more gassy. This one blew up the SSE (cathode resistor and cap).
A 6CB5 just running a wee bit above the dissipation spec in an SSE. Yes, it does sound quite good.
A pair of 6BQ6GA's operating beyond the red glow zone....into the white glow zone. You could feel the IR radiation across the room. The amp sounded quite good, and played for about 45 minutes until I shut it off. The tubes didn't work so well when I turned it on the next day though.
An 833A operating WITHIN its maximum ratings.....the glow is NORMAL.
A 211 that I got for $5. It blew up the amp!
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old Yesterday, 11:58 PM   #4
smoking-amp's Avatar
Tube got hammered.
Tube concussion.
I want a Huvr-Board!!
Old Today, 01:45 AM   #5
Matt BH is offline Matt BH  United Kingdom
The "white glow zone" I love it George!!
They must have been out-gassing big time! Not surprised they didn't sound so good after. Should have kept em hot and kept em glowin😃
Cheers
Matt.
Old Today, 01:50 AM   #6
Cheers
Matt.
Old Today, 02:01 AM   #7
Way back in my childhood I figured out that the TV sweep tubes (line output) 6BQ6 and 6DQ6 have the same pinout as the common audio tubes like the 6L6GC and 6V6GT if you wire a plate cap to pin 3 of the socket. This led me to sticking them into a Fender Champ. At the time I didn't understand things like impedance or bias, so I didn't understand why the little tubes (6BQ6) were louder that the big ones (6DQ6). It took ma several months, but those and other experiments eventually let the smoke out of the Champ's power transformer.
I was about 10 years old at the time, but within a few years I was scratch building "Champs" out of TV tubes. As you can see the madness continues 50 years later. I stuck some 6BQ6GA's into an SSE and proceeded to explore their upper limits.....I have several hundred of them, so I "tested" some of the uglier looking tubes.
I was getting about 20 watts out of those before they fried in that SE amp. I have extracted about 100 watts from a pair in P-P without any glow! In fact I have an amp design in the works that gets about 125 watts per channel from 13GB5/XL500's.
Sometimes you just have to fry a few tubes in order to figure out how not to.
what is this valve? and what is it for?? ncdrawl Tubes / Valves 5 24th December 2013 01:12 PM
Short wave Valve transmittor :) what valve is best? sco1t Everything Else 89 23rd November 2012 08:42 PM
valve sub skal Tubes / Valves 0 24th September 2009 06:54 PM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 12:15 PM
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Tubes / Valves 11 6th September 2005 09:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
